If it goes over 90 you have a problem, you fix the problem = you have the correct temprature,Draco wrote:RAW wrote:Draco wrote:
Mr. Rezlo, I know much less about engines and stuff than you, so I'll take your word on this, it sounds logical....if you one day know for a fact what will get me that inlet temp costantly without fail....let me know please.
If its rocketing due to added power (stock radiator can support a good 220kw-230kw odd in summer), you need to upgrade your radiator, obviously as your power goes up you need to take it further.
I bet you that your radiator is 1/2 clogged and your waterpump and thermostat need replacing, or your fan clutch is failing.
Along the lines of what Sokar said, OEM's use specific types of fluids because they work best or last correct amounts of time before break down, if there were substantialy better and "safer" options trust me you would see it in the OEM's or proper racing cars first.
