SoundProofing
please let us know of the results when your done, I am very interested to find out the difference it makesGary57 wrote:Yeah it wont go to waste. I think there should be enough to do the boot and the bonnet. I might not do the bonnet and do the fire wall, it makes more sence that way.
BTW: remove the passenger kick panel and go for a drive, you will be shocked at how much noise that kick panel stops.
Ok so I fitted the RoadKill last year and it is a real good product, very easy to apply.
I did the entire boot; the wheel well, back of tail lights, pretty much everything you can see when you lift up the boot carpet all the way to the back seat. This took 16 pieces of Roadkill.
The outcome was good I would say. I dont really drive according to the speedo but more to the sound of the car (I know what the car sounds like at 130km/h), once I fitted this I found myself driving at 150-160km/h instead of the usual 130km/h. So that will give you some idea of how much quieter the car has become.
After driving around for 3 weeks I wasnt quite happy with how quiet it was. I had this great idea of how quiet I wanted the car and the Roadkill didnt do it, well not all of it. Dont get me wrong it did help but not as much as I wanted, I suppose it can only do so much.
So I went in search of something else to aid in the soundproofing. Now the carpet in the boot has underfelt underneath it (as standard) and mine was a bit worse for wear so I decided to change it. Got a off cut from a carpet layer for R100. I pulled out the whole boot carpet, off the back of the back seat, traced the shape and cut it out. I simply glued it on the back of the carpet with contact glue and put it back in the car.
This underfelt made more of a difference than the RoadKill did with out a doubt. The rear of the car is so quiet I can only hear the exhaust after 4000rpm.
