Temporarily until I can get to it to fix it properly and when I have a bit more time... its pretty difficult to get to u knowToby wrote:So you've bypassed the only protection your engine has gainst total meltdown?
Reading Fault Codes
- Toby
- Club Founder
- Real Name: Toby Kurien
You can't just swop out the AFM! You must remap the ECU with the characteristics of your new AFM (much like you need to remap for different injectors) otherwise the fuelling will be all wrong and can lead to massive detonation.
- GoldenEagle
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
What problem are u referring to exactly?GoldenEagle wrote:I realize this thread is relatively old, but has the problem been fixed?
The fact that I couldn't read my fault codes coz I was being an idiot?
If ur referring to the det sensor, I'm getting a brand new one from Nissan...
- GoldenEagle
I was referring to the fact that you could not read the fault code. I could not figure out which code it was either...going off of the diagram you put together.Trance101 wrote:What problem are u referring to exactly?GoldenEagle wrote:I realize this thread is relatively old, but has the problem been fixed?
The fact that I couldn't read my fault codes coz I was being an idiot?![]()
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
Oh ok, well it turned out the problem was with the userGoldenEagle wrote:I was referring to the fact that you could not read the fault code. I could not figure out which code it was either...going off of the diagram you put together.Trance101 wrote:What problem are u referring to exactly?GoldenEagle wrote:I realize this thread is relatively old, but has the problem been fixed?
When u first turn the screw on the ECU fully clockwise it starts flashing codes for the different modes u can choose. ie 1, 2, 3, 4 ,5 denoted by that number of flashes.
For self diagnostics you need to choose mode 3. So, after it has flashed 3 times turn the screw fully anti-clockwise.
Now, it will flash the fault codes. The number of red flashes make up the first digit of the code and the number of green flashes make up the second digit of the code.
When I first looked at mine I couldn't see the green light as it was mostly covered by the edge of the window...
Here is a good thread about it from another forum.
i'm quite sure someone said "RTFM".
had you have read it, then you would've come right first time
you turn it all the way right till it starts flashing and you turn it back when the right mode is selected.
