Parts?
Well you can stare at my cars rear with the stock nice lights
							A.K.A -  Wonderboy
- johansx
On the 4x4 LSD we use Castrol LSX... Yip the easiest way to test is to jack up both sides. If it turn in the same direction, its a LSD. If some stupid appy put normal oil in, we flush and add Castrol LSX. Work again after that.Gary57 wrote:Are you sure that works?? The LSD cant be that sensitive, can it??if the other turns in the same direction then its LSD. if it turns in the other direction then it isnt LSD.
I jack the rear of the car up put in first gear on drive it on idle then try stop one wheel, if you get thrown to the front of the car the it is LSD if the wheel stops then its not.
I know if you dont put the correct oil in the diff the visous packs up and so does the LS, the oil you can only get from agents and they will fill it (wont sell it over the counter).
Had 2 sx's in now that the LSD doesnt work and it is because they used normal gearbox oil.
where can i get that wing? i really love the look of it. And the lights? prices on that wing...?Sokar wrote:Ero_sennin wrote: In my opinion the only tail lights for an S13 are the type X lights.
yeah - please give the insurance details so i can go buy the car from them!!!dwayne wrote:but any way the car is going to be writen off!!
the insurance says not neg! went to the car today man she still looks good! only wish i could get ritht side suspension then she can drive again
i need another driftpig!!!
