Project s13 RB25 Neo Capetown
Re: Project s13 RB25 capetown
thanks man just cant wait to start up.
eazye
Engine: 1JZ
Real Name: Jade
Post by eazye »
u going 2 come join the Drifters?? if so...check out https://www.facebook.com/GrassrootsDrift
Initial D-rifter
eazye wrote:u going 2 come join the Drifters?? if so...check out https://www.facebook.com/GrassrootsDrift
when its done will do for sure [smilie=200sx_200sx.gif]
Head had to come off due to motor boosting water, bought the motor like this so hoping no damage to block or head.
Cylinder head off and see theres one ARP head bolt missing it was replaced with oem head bolt, can any body help me find one ARP head bolt please.
Looks like i found the problem, the hole deck of the block is smooth except for the area surrounding piston number 6, what you guy's think?
Engine mountings completly done :D must just be neatend up an coating.
djtreble
Post by djtreble »
That block needs a skim, and the piston has also suffered a bit too much heat, you may run into issues with it so replace it while it's out.
www.rotawheels.co.za
www.kaihatsu.co.za
djtreble wrote:That block needs a skim, and the piston has also suffered a bit too much heat, you may run into issues with it so replace it while it's out.
aggg i didnt want to strip the bottom end :( but what can you do.
eazye
Engine: 1JZ
Real Name: Jade
Post by eazye »
she going 2 be runing soon? 17th is some Drift prac
Initial D-rifter
Agree. The piston is rocking and touching the head by the look of things..check for corresponding witness marks on the edge of the combustion chamber in the head.
If it is touching, its a possibility that it may have hurt the big end as well. Maybe not. I have had it where the piston will rock on the gudgeon pin and the bearing will be good.
If its already touching you may have to deck the piston tops as well to clear ..
Id also check piston to bore clearances while its undone..
eazye wrote:she going 2 be runing soon? 17th is some Drift prac
Dont think so bud :(
Thanks for the help bk and you just spoilt my day with this news :( lol
RB25SX
Post by RB25SX »
It might be cheaper to just go buy a RB25DET Neo , instead of rebuilding. :wink:
R32 GTR
RB25SX wrote:It might be cheaper to just go buy a RB25DET Neo , instead of rebuilding. :wink:
What!!!!!!!! i just bought this motor, i did not evan start it up yet :cry: :cry: :cry:
Sorta wished you stayed with the SR hey..
Draco wrote:Sorta wished you stayed with the SR hey..
we warned you of the risk :facepalm: hopefully it doesnt cost you to much
