Project F
Hey Chem!
Just read your whole thread! Damn man!
You went through all this and you still prevailed! Nice!
Oh and I'm glad your love for the SX is restored again!
Just one more thing... are you running the t28 now? what mods do you need to bolt it to the standard ca18? Oh and is it possible to run it of the stock ecu?
Sorry for all the questions
Cheers Riekert
Cheers Riekert
- ChemCool
Riekert, I like to stress that I always had the assistance of one or two of the club members with me, while the rebuild was on. Thanks to them again.
Here are some pics of the engine bay, just after the modification done on all idle control pipies removed,
BTW: The strut braces by GARY !
The stainless steel by CHEETAH EXHAUSTS in Rosslyn Pta.
Chem
Chem
Ah thats cool, was also thinking of doing that t28 mod...ChemCool wrote:Thanks, Riekert.
No problems.
Yes it is about a t28. Bolt on std No issues with that. .64 exh housing. Stock ecu is fine with it, altho I use a unichip.
Chem
See thats way I'm asking... with guys like you, VC, Vlade and all the rest you can't go wrong....ChemCool wrote:Riekert, I like to stress that I always had the assistance of one or two of the club members with me, while the rebuild was on. Thanks to them again....
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
Do u have dual w/m injectors there ChemChemCool wrote:
Love the look of your engine bay with all the red piping btw
- ChemCool
Yes, it is dual. The one close to the turbo is a bigger nozzle, and the nozzle close to the tb is smaller in spray pattern. Keep in mind I don't use fmic, When you use fmic, this dual set up would be unnecessary. One nozzle would then be fine.
The choice of nozzle sizes in this set up is paramount. To prevent quenching: In my case the bigger nozzle is 225 ml/min and tb nozzlle 60 ml/min.
I still need to replace the tb nozzle down to 60 ml/min. Currently running a 175ml/min, which I get the gut feeling is slightly to big.
A possibility is then to reduce the pump pressure, but I dont like that.
Chem
Chem
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
So, would I be correct in saying that the dual setup is to prevent the temperature dropping too rapidly and having adverse effects on the metal piping?
And then with an intercooler this isn't needed as the temperature has been lowered some what by the intercooler before hand.
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
w/m and an intercooler do the same thing (well in terms of cooling the intake charge that is) and the effects will compound. So, ya I'd say its a good idea. But as ChemRiekert wrote:So it would be a wise choice to go for fmic and w/m?
