Devil Pig Drift / Track car S14 Ls1v8
Re: Devil Pig Drift / Track car S14 Ls1v8
Falling Sky hey?
Booster
Post by Booster »
Charlvdw wrote:Falling Sky hey?
u got me. Im lost??
u got me. Im lost??
No never mind, if it doesn't make sense to you my assumption is way of.
Booster
Post by Booster »
Updates,
Busy working on fitting body kit,
Then my biggest concern is now finally dealt with.
I had fitted electronic oil pressure guages with gimics like oil pressure warning lights and buzzers. all sounded so cool
What a crack a shit
Reverted back to a mechanical oil pressure guage for acuracy.
Becouse I am running a dry sump system, i have an external pump.
So if the belt breaks and or pump siezes or any other reason that would cause a loss of oil pressure.
With my current system i would never know as while driving im too busy to look at guages.
So to ensure reliablity and make sure that this motor lasts i fitted a adjustable pressure switch. N/0 from 1-10 bar
And i connected it through the ECU Power supply.
So when i hit the desired pressure in this case 1.5 Bar, the switch opens and power to ECU is cut.
System works great and will def give me piece of mind now while driving.
Also been working on getting cooler air through the engine bay. After 2 laps the car gets HOT ...I MEAN HOT
So raised bonnet
Increase cool air supply.
next steps is to relocate the oil cooler as i belive it is blocking air to radiator.
Test at rock tomorrow and check temps atc.
FInally also dialed in the suspension now acuratly and properly so keen to see how it responds.
Real Name: ????
Post by Adrian »
Seen a something like that before. Was just cutting his fuel system
Shout if you want glass rear 1/4 vent windows... 8)
dam nice might come to the rock just to see this!
Real Name: ????
Post by Adrian »
hahaha love the bumper stands ;p
RB25SX
Post by RB25SX »
Booster wrote:,
Do u have to crank the motor till there is oil pres, before it will start, or swithch ecu on?
R32 GTR
Booster
Post by Booster »
Ahh a man who is awake!
No i dont. I fitted a bypass toggle switch to bypass the manometric pressure switch.
So when i start the bitch, and the pressure comes up. i flip the toggle and the fail safe activates.
Happy days
Booster
Post by Booster »
BigKriss wrote:Shout if you want glass rear 1/4 vent windows... 8)
barry you are an evil man. You will do 2 things
Make me broke
Make me single
G, I would not shut down the ecu in this case.
I would rather go for the ignition ignitor but if I remember correctly you do not have an integrated ignitor to disable.
Then I would go for the positive side injector feed.
Too much can go wrong with shutting the full ecu i.m.o. I would be concerned about an ecu failure.
Come collect them bud, in my office cupboard at the mo.. 8)
Booster
Post by Booster »
updates,
Last wednesday was total disaster at the track in terms of practice.
In the short time i did drive im well impressed with the cooling changes. The car is running much more efficiantly now and 5 degrees cooler.
Still some duckting i want to put in place which Barry recomends. That should get the temps right down
Some new goodies to test this wednesday at track.
Big thanks to Barry, you are the man.
Brembo rear calipers with Subaru Wrx sti disks. Also added a new spacer on the back for 20mm wider track. In search of more rear grip
New stance and offset
saw this car at the track real impressive!
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Post by P3g4sus »
Hey man, whats your alignment at the back? Is everything square? That could be a big thing in traction as well
