Pinkfluffybunnys
Posts: 1693 Joined: Thu May 08, 2008 1:21 pm
Real Name: Ashley
Post
by Pinkfluffybunnys » Sun Jan 16, 2011 8:17 pm
Intake manifold - Un-ported
After Porting.
I'm going to use the IAC valve from a CA18DET
Here is some info on the intake.
Velocity Stacks are 52mm
Port size's are 52mm by 31mm
Length from Velocity stack to port is 23cm
Lindt
Posts: 366 Joined: Fri Sep 04, 2009 5:09 pm
Post
by Lindt » Tue Jan 18, 2011 3:11 pm
mr fluffy bunny and his port matching, LOL.
That q45 will work better on my new project, think I must give you a refund
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Wed Jan 19, 2011 7:17 am
NNNNNNOOOOOOOOOO
LOL, Im so close just need the TB
Lindt
Post
by Lindt » Thu Jan 20, 2011 12:36 pm
you want to go and race sperm at ODI
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Thu Jan 20, 2011 12:40 pm
LOL
Maybe
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Sat Jan 22, 2011 8:23 am
Intake Install
200SX CA18DET IAC Valve
Test Fitting
TB Compare
Q45 VS 65mm
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Sat Jan 22, 2011 7:47 pm
OK So problems.
I cant find a 90mm to 76mm reducer anywhere in PTA.
I'm using a hacked 85mm to 80mm reducer but it has started to tear so, I urgently need to find one.
Secondly my Neutral switch trigger isn't working so the car is high idling sometime's at robots (will try and sort it out tomorrow).
Tune
Idle is the Same
Cold Start is the Same
Hot Start is the same.
I needed to add allot more fuel on my acceleration jet map to keep the fueling stable when putting my foot down.
I also had to increase fuel through the whole map especial the top range under WOT.
Impressions -Butt Dyno
Down Low power has increase lightly the car does seem to pull better between 3000rpm and 4600rpm.
In Lift the car is allot stronger especial between 6000RPM and 8000RPM.
I'm getting very bad torque steer now when planting it.
I now need to get the car on Derm dyno but I need to find a reducer first
NIZAN-R
Posts: 1201 Joined: Tue Jan 08, 2008 10:11 pm
Real Name: Renier
Post
by NIZAN-R » Sun Jan 23, 2011 2:06 pm
looking good dude bet it pulls like a MONSTER!!!!
thanx for helping my brother out with his car.
She is not the
CA that could be
She is the
CA that IS
O = O )/
RS13 \(
O = O )
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Mon Jan 24, 2011 6:55 am
Thanks Dude.
Dont worry about it, Your bro needs to get a set of cams now.
Lindt
Post
by Lindt » Mon Jan 24, 2011 8:00 am
should have told me, I have 3 of them at home, only place that sell them is universal coolers.
www.hot4cold.co.za
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Mon Jan 24, 2011 8:08 am
Sweet.
I will drop you a mail
Lindt
Post
by Lindt » Wed Jan 26, 2011 12:33 pm
she's a screamer........
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Wed Jan 26, 2011 2:38 pm
LOL
She like being driven Hard.
I need to drop you those links about the VE head and stuff.
Lindt
Post
by Lindt » Wed Jan 26, 2011 5:02 pm
ye, it'll be awesome. VETurbo, sounds right, hahaha
Pinkfluffybunnys
Real Name: Ashley
Post
by Pinkfluffybunnys » Sat Jan 29, 2011 5:45 pm
Picked up my new addition from Derm Yesterday.
Collector
Fitted.
Still Tunning..
Will give my impressions tomorrow.
