Page 12 of 31
Posted: Sun Apr 22, 2007 7:45 am
by Rezlo
It does happen, im not denying that, especialy on NA cars, infact on NA cars with HUUUUGE cams and ITB's you can actualy see a vapour above DD carbs do to overlap and reverb
Its just that on turbo cars, especialy ones with TINY duration cams it is highly unlikely, especialy when the runner length is increased. I see the one guy was talking about it happening on a gtst, the runner lengh on that motor is about 100mm if that, and with the VVT it gives it that added timing it needs.
I would just say there are to many things that are 100 times more likely to have caused this dammage like slag from your freashly welded bov flange, pieces of valve guide ectr that could had hit the exhaust valve not letting it seat then make its way down to the turbine and cracking it, once cracked and having a dammaged exhaust valve the chances of it getting sucked back are DAMM good.
Just for interest sakes what do you think caused the guide to crack? thats somthing you dont see every day on CA or SR's
Not trying to cause shit here vlade, and if you want me to stop replying in your post just say the word, im just trying to give some practical experience tips to what i think it could have been to save you from possibly having the same problem again.
Posted: Sun Apr 22, 2007 8:20 am
by The Calibrator
Seeing as the valve guides were not replaced when the head was reconned its a possibility that the piece broke off ages ago.
Strangely enough it was definitely pieces of Turbine impeller imbedded in the pistons and cyl head. Same shape same thickness same magnetic properties.
So if what I have said is impossible then how did the pieces of turbine impeller get into the combustion chamber?
Remember the compressor turbine is in perfect condition.
Posted: Sun Apr 22, 2007 8:28 am
by Rezlo
piece of slag breaks off bov flange that was just welded on, gets sucked in, bends the intake valve a touch possibly cracking the valve guide, makes its way out the combustion chamber clipping and exhaust valve on the way out, all of which is completely possible, then it hits the turbine wheel cracking it, due to valves that are not seating there will be a suction on that runner, sucking bits of the wheel back into the combustion chamber, from there it is quite possible to suck it right back into the intake manifold which the car is at idle due to intake manifold vacuum, this would enable it to be distributed pretty easily threw the rest of the cylenders making the dammage to where it is now.
Vlade did you inspect the head before sending it to them, or inspect it when you got it back? chances of them not noticing a cracked guide is very very slim, and the chances of them not tellign you it has a cracked guide to make some money out of you is even more slim.
But does what im saying make sence?
Posted: Sun Apr 22, 2007 10:28 am
The BOV was not welded on at the time that the engine was running
Did that a day or two before taking it to Duane's shop, by that time it was already F#cked.
Posted: Sun Apr 22, 2007 6:32 pm
by The Calibrator
The valve guide that was broken was a Exhaust guide and evenly coated with carbon so it had been broken for a while. Plus the car ran evenly on all 4 cyl except when bits got trapped between the valve and seat.
Plus I did a compression test which showed up fine. I reckon that pretty much rules out the bent valve theory.
End of the day I have my theory you have yours. I have no agenda with mine, you have to try and protect your product.
Bottom line is the motor and turbo are somewhat tired and are getting fixed. As far as I am concerned thats all that matters.
As for Vlade's comments about your unbranded products I recall changing SR20 Sumps a few times due to crap castings.
What you sell is your business but you cannot bitch when people complain about substandard products just as I cannot complain if people bitch about shit service on my part.
Posted: Sun Apr 22, 2007 7:29 pm
by Rezlo
Im not trying to protect my products, I told you ive already removed them from my site and I do not sell them any longer.
And yes duane, you had 2 oil pans that leaked, as soon as this problem was noted I contacted every customer I had ever sold one to, luckily non of my other batches ever had this problem. I went threw my remaining stock of 15 and threw away 4 which looked semi suspect, the rest i put an NPT plug into each locator, that way even if the pan was perfect there was no chance of it leaking, once that stock had been depleated they were also removed from sale, not one so far has had a leak.
One thing that amazes me about some south african consumers, you prepared to take the risk of running knock off items, but when somthing happens you are the first ones to cry, Myself and Jerry both sell HKS, Silkroad ectr headers at R7000 odd a pop, and we both sell ARC and Greddy oil pans at R4000-5000 a pop, in 3 years Ive sold 1 of each? Yet the remaining people (well over 100 in SA with not one other faliure) would rather buy knock off items knowing full well they are not the same quality, well catch a wake up, if somthing goes wrong bitch, but remember you are the one that desided to run the risk of using a knock off part knowing full well that the chances of somthing going wrong are alot higher than the equivelant name brand item..... I spent hundreds of hours and probably 30-40 sample orders from companies all over the world trying to find the best items to sell here at the most reasonable price, yet when somthing goes wrong which can not even be corectly pin pointed on my product i sold I get physicaly threatend in multiple posts on a publicaly hosted forum?
Thats real nice, thanks.
Again, vlade, I hope you come right, its never nice spending money and having it go up in a ball of smoke.
Posted: Mon Apr 23, 2007 10:19 am
my two cents on this:
rezlo - the following may sound harsh to you, but my intentions are completely constructive. please understand that before you read further.
rezlo you have a tendency to contradict yourself, and you should be careful. it makes your arguments sound weak. for example, you kept posting your opinion that bits of exhaust wheel couln't possibly find themselves in the combustion chambers. then, a few posts later, you say that it is possible that they were there, as long as they were knocked off by slag from a BOV flange weld. strange dude.
you also have a tendency to ignore the proof on offer. both vlade and calibrator say that they've seen exhaust wheel material in the cylinder head - yet you keep on pushing the theory of the valve guide breaking. these guys have no hidden agenda's, and they just want to get the engine running again.
then you bitch and complain about south african consumers - your own customers. i dont think thats a way to go about running a business, no matter if its your hobby, or if its your livelihood. if you feel so strongly that the knock-off products are inferior, why do you offer them for sale on your site? that i dont understand. i would think that you are confident in the products that you offer - but you should reconsider selling them if they're inferior. your process of buying and testing first is a great initial step in quality checking though, but perhaps full returns, or short term guarantees should would also help.
Posted: Mon Apr 23, 2007 5:44 pm
by Rezlo
I never said couldnt, I said its highly unlikely that a car with stock cams and a stock turbo could do it, unless there was a problem, I just didnt post what that problem could be untill later. Once somthing has gone wrong then its easy for it to get sucked back but without somthing wrong in the head its unlikely to near impossible for the turbo to go bad and suck it back into a perfect working motor if that makes sence. Valve guide bending the valve would cause the ability to suck the bits back, but as duane said after i wrote this that the valves were seated perfectly...
I do feel knock off items are inferiour to name brand items, yet i wouldnt just sell any junk made, i went threw the hastle of finding decent items, I even run a turbo manifold from the same supplier on my RB, on my old SR20, on the RXM race cars ectr.
I am also getting rid of (pretty much gone) that whole side of rezlo.com, due to the market being flooded with real junk over the last 2-3 months, which im sure you guys will very soon find out about.
unless its a blatent manufaturers defect not even name brand items can be returned, near every performance item made does not come with a guarantee due to the shear nature of racing and performance items. Again unless it is a blatent manufacturers defect, unfortunatly thats not just me, but thats the actual suppliers/manufacturers.
And im not putting down the south african customers... even myself, I will not go and buy a HKS R7000 turbo manifold for my RB if I know full well the R3000 one I sell will do 99% of what the HKS one can do, but you know what, if in 3-4 years it breaks I have only myself to blame for not going HKS in the first place, which BTW also fail, its just a case of working out if its worth the risk or not. And being south african not many of us have the ability to buy Brand name items, so we settle for 2nd best, but we shouldnt forget its still 2nd best and items do go wrong and do fail and unfortuanatly that is just part of racing and performance.
I honestly have a shit way of saying things, and often what i say gets taken the wrong way, but re-read what ive said in the previous posts, i was just trying to help, and me posting in this thread is doing nothing but waste peoples time reading it, so I will not post in this thread again.
Posted: Thu May 24, 2007 1:42 pm
Any updates?? How long before Duane has it on the rollers??
Posted: Thu May 24, 2007 1:50 pm
Nothing yet... CP said 4 to 6 weeks for the custom order, we only in week 4 now, plus I must not forget the 4-10 day shipping.
I phoned JIMC (Jhb International Mail Center) to trace an incoming parcel, they have a huge backlog, due the people gone import crazy because of the lekka exchange rates.
Posted: Thu May 24, 2007 9:50 pm
by Ero_sennin
This time it should work out fine
Posted: Fri May 25, 2007 7:21 am
Yeah I'm pretty sure it will...
Posted: Wed May 30, 2007 8:01 am
Well my suppliers JGY Customs will have the pistons before end of this week, so the will be in my hands before the 10th of June
Posted: Wed Jun 20, 2007 4:52 pm
Yeah it took long enough finally its here!!!! Yeah now to get on with the building process, that I will leave in Duane's hands.
That is what I needed... waited 13 weeks for it, due a mistake on my side and on my suppliers... so yeah, oh well.
Posted: Wed Jun 20, 2007 5:10 pm
by qewrty
Vlade wrote:Yeah it took long enough finally its here!!!! Yeah now to get on with the building process, that I will leave in Duane's hands.
Sweet. How much deviation from stock is this CA going to be, esp power wise?
