if you grind that manifold then you will officially be a tjop!!! i will come find you and moer you with the grinder.
listen to hando...
its only a couple of degrees, so do it. you dont have to clock it 90 degrees or anything. and its easy - loosen a few bolts and turn it, then tighten the bolts - easy!!!
plus you need to do custom piping for the cooler anyway!!!
DO IT!
listen to hando...
DO IT!
OK OK!! I wont grind the manifold...
I'll clock the turbo...
Plus like VC said I 'm gonna run new piping.
Ok will do it over the weekend.
hehe! nice! dude I'm busy with work. but thats no excuse. I'll have them fitted by this weekend.HancoB wrote:And riekert you take longer than eskom to fit those lights...
When can you shed some light on this subject?
