yay another problem solved!!!
Re: yay another problem!!!
ok cancel that thermostat is working fine any other ideas im all out?
ok is water returning from the block to the rad?
ja the return pipe gets hot so thats fine
Anyone?
http://forum.miata.net/vb/showthread.php?t=374132 hi guys acording to this thread the CAS is faulty does anyone have one that i can test if thats what is causing my problem? PLEASE im located in jhb
Ok so thanks to Doctor G on the Nissan owners club the problem has be sorted out :D turns out it was just the idle was to low and as soon as the cold start switched ff the revs dropped and the motor died just a quick adjust of the idle and problem solved :oops: thanks for all your help guys [smilie=200sx_200sx.gif]
