but didn't make a noticeable difference pinched the vacuum line to the dump valve and that seemed to fix the problem where it dies. is this just because the motor doesn't like atmospheric dump valves or could i have connected it wrong? i ran the vacuum line to the dump valve from the vacuum line going directly into the side of the intake.......is this wrong?reving slow
Re: reving slow
so cleaned my afm this weekend was dirty
but didn't make a noticeable difference pinched the vacuum line to the dump valve and that seemed to fix the problem where it dies. is this just because the motor doesn't like atmospheric dump valves or could i have connected it wrong? i ran the vacuum line to the dump valve from the vacuum line going directly into the side of the intake.......is this wrong?"I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me"
Re: reving slow
Your dump valve is probably leaking, thus causing the motor to lean out too much on idle.
Increase the pre-load so that it doesn't pull open under idling vacuum. If it leaks while idling, I presume it drives like shit at small throttle openings.
