I thought I would do a little write up on the installation of the NISTune Type 3 board and show you how time consuming and involved it is turning your OEM ECU into a stand alone unit.
Step 1 - Locate your ECU
Time - 5 Minutes
Find your OEM ECU
Step 2 - Remove OEM ECU and bracket
Time - 2 Minutes
Step 3 - Remove ECU covers
Time - 2 Minutes
Step 4 - Solder in 40 Pin Connector
Time 45 Minutes
Step 5 - Install NISTune board
Time 1 Minute
Step 6 - Install ECU
Time 5 Minutes
Just look at that cut up harness hope my soldering holds, Thats not right, I forgot I didn't cut a wire,Next load the Start-up map and head to the dyno, No Wait? That's not right aswell
Ow Yes, Just Load your stock Nissan Map and start the car and drive, That sounds Right
Step 7 - Plug in your consult cable
Time - 5 minutes
Now you can start tuning , On the stock map keeping all your stock functions,No step up motors, no crank angel sensors, Just plug in and go tuning.
Time to see what the stock motor can do
Total Time: 1 hour 30 minutes
