Accidental 1.5Bar boost
Ok which TD04H?
Do you have a T, G or c wheel?
Also what Size comp? 13,14,15?
Because the Td04h-18g just fits the Spec's of a garret T28 Unit.
Also depends on the Specs and trim of the wheels and A/r of the T28 unit.
Most of the Uno guys I know run a Td04h-15T to 1 bar.
15T. The turbo is too small i had to modify the internal wastegate port because the boost would creep to 1.5bar with the wastegate fully open. the button on the wastegate was 22mm and i had it made to 28mm, if my memory serves me right or was it 32mm ah shit not really sure. A few guys in Aus get 220RwKw with std internals and this turbo, so i think 200RwKw is a decent goal.
Hmmm
No problem
OK we will have to see the dyno charts
Good Luck hope you get the numbers
No problem
sounds like u dont believe?? what is the max my turbo can push then, u obviously know more than me (who drives the car everyday) and the other 5 or 10 guys in Aus with the same mods making roughly the same numbers. i will take anyone for a drive next time they in dbn and show them the 1bar at 2750rpm (which seems unbelievable to most) and will floor it and let them decide how much power is there.
Ok Slow down there "Internet tuner" , I wasn't being rude to gary57 .HEHE Phinx strikes again. Dont worry Gary he has this habit of telling people who have actually have the T shirt how it really works whether he has the T shirt or not.
Im sure he can push the numbers on his set-up and has the dyno sheets to back it up.
He assumed that I was saying he was lying , I just asked what TD04H he had thats all.
An assumtion as the saying goes ,makes an "ASS" out of "U" and "ME" ---- "Assume"
The same way your statement did
