Does anyone sell the R300 in this country?? I have a EGT display already so that is no problem. The LM-1 logs AFR but you need to buy a seperate module for rpm, boost, ignition, egt, etc. It then is getting too expensive.
I have a R300 as well works pretty good I use the 0 to 5v output to datalog to my efi live ram mapping software. Lumina only before u all get excited.
Local stuff Perfect power makes a WBC which work pretty well and is cheap LAst I was getting them for just under 2k. Only problem is its Leds not digits and the connector is on the front so its difficult to dash mount.
What are the chance any of you guys know the output of the LSm-11 wideband O2 sensor?? I need to know if it is linear or follows the same curve as the LSU-4??
The LS11 is probably voltage based while the LSu4 is current based. Therefore the raw output will different.
The 0 to 5V output of yr meter should be in the manual. Something like AFR= Voltage*10/2.
Tip
Connect it to the wolf input and see if it displays anything near sanity on the hand controller.
