S14 Stuck
Re: S14 Stuck
I run a in line "fong kong" in my tank and is still fine...but if you can...get a walbro
SilviaS13
Club Drifter
Engine: 2JZ
Real Name: Ernest Simpson
S14 Stuck
Post by SilviaS13 »
You come right? Get original. Jerry has from import oarts
drifterz do it slideways...
White Fang
Real Name: Qubitt (Qbit)
Re: S14 Stuck
Post by White Fang »
Did you get sorted ?
i have a few pumps at work for you !
Not Far from where you stay !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
shiraazz
Re: S14 Stuck
Post by shiraazz »
will I need to modify anything else on the car?
Driving is not my hobby, it keeps me sane
___________________________________________
Current : 1996 S14 200SX
Will be back : 1999 E39 540i
RIP : 1994 E36 325i
Ex : 2001 Daihatsu Coure 1.0
Ex : 1993 Jetta II
shiraazz
Re: S14 Stuck
Post by shiraazz »
@white fang plz pm me your number
RIP : 1994 E36 325i
Ex : 1993 Jetta II
SilviaS13
Club Drifter
Engine: 2JZ
S14 Stuck
Post by SilviaS13 »
If you don't come right let me know, I still have my stock one somewhere
shiraazz
Re: S14 Stuck
Post by shiraazz »
How many bar does the stock one push?
RIP : 1994 E36 325i
Ex : 1993 Jetta II
SilviaS13
Club Drifter
Engine: 2JZ
Re: S14 Stuck
Post by SilviaS13 »
not sure, but I know the walbro pumps 255l per hour. and my car is set on 4.5 bar
shiraazz
Re: S14 Stuck
Post by shiraazz »
You can adjust it?
RIP : 1994 E36 325i
Ex : 1993 Jetta II
Re: S14 Stuck
shiraazz wrote:How many bar does the stock one push?
The fuel pressure regulator will keep the pressure the same.
Just incase your worried a larger/stronger fuel pump will somehow overfuel your engine now.
shiraazz
Re: S14 Stuck
Post by shiraazz »
What is the benefit of the larger pump then, maybe im being doff
RIP : 1994 E36 325i
Ex : 1993 Jetta II
Grant222
Engine: 2JZ
Real Name: Grant Jones
Re: S14 Stuck
Post by Grant222 »
benefit wil be that it wil always keep up and if you turn up the boost or go biger turbo then the pump is there
CC Motorsport
Real Name: Geoff
Re: S14 Stuck
Post by CC Motorsport »
it prevents fuel spikes basically
fast is just not FAST enough
shiraazz
Re: S14 Stuck
Post by shiraazz »
Is it an easy job to replace?
RIP : 1994 E36 325i
Ex : 1993 Jetta II
CC Motorsport
Real Name: Geoff
Re: S14 Stuck
yup preety much just 2 hint's
1- do not smoke while carring out your work
2- have some few socket's and ratchet
3-long nose
4-try not get it in your eye
