CA not reving above 4k
- rat
- Real Name: Rat
Re: CA not reving above 4k
Epic FAIL
Fitted new fuel pump and the cleaned AFM same problems. Fitted another working AFM no difference. checked error codes on ecu and got 55
I really thought the pump was the problem.
bugger...
Strange its finding no faults....does it sound like a limiter or is it just being sluggish and stopping around there?
NIZAN-R
- Real Name: Renier
http://www.silviawa.com/forums/index.ph ... opic=41897
boost leak test
ps dont put too much presure and spray some water on the joints to reveal leaks
boost leak test
- rat
- Real Name: Rat
In neutral you can press the pedal to WOT and it will rev to 4k and bounce like a limiter.djtreble wrote:Strange its finding no faults....does it sound like a limiter or is it just being sluggish and stopping around there?
Might have found the leak, held my hand over the intake pipe while the car idled and heard air sucking in from the IC. How do you get to the STD S13 IC?NIZAN-R wrote:http://www.silviawa.com/forums/index.ph ... opic=41897
boost leak test
NIZAN-R
- Real Name: Renier
remove the fender liner plastic in the wheel arch
Check your cam timing.
If the cams are off a single tooth they will do exactly what you describe.
Did it run before? Were the cams removed?
- aep886
- Real Name: Davey
the same thing happen to my sentra... it could not rev~ a cracked head><
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- rat
- Real Name: Rat
Found a boost leak, one of the pipes from the ic was loose. Made no difference.
Don't know if the cams have ever been worked on. Will check the timing during the week. Hope it is not a cracked head.
- aep886
- Real Name: Davey
on the S14 if the ic pipe are lose...and try to rev to 4k just once~
then the engine will actually shut off....
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
The symptoms do not sound like boost leak. Any chance of a video of it doing it? Does it also do this in gear when driving? In neutral if you rev it up gradually does it still limit at 4k?
Also are you absolutely certain it is standard in the engine management department, including the wiring?
- rat
- Real Name: Rat
Yes, everything is there.djtreble wrote:Also are you absolutely certain it is standard in the engine management department, including the wiring?
