Hi Guys, Has antyone managed to check the pic on facebook of the new vs old turbo ? I have fitted the turbo - I have lag and it only boosts 0.5 at peak revs ????
I will let it cool down and adjust the actuator and see what happens.
djtreble wrote:Oh wait hold on, I thought you were talking about the T28...can you give me the full Garrett code for it (eg. GT2871R)
Hi Dj
please see the link below for the turbo I purchased...
It does not boost more than 0.5 at peak revs and there no boost at the bottom? is this turbo too large or have I done something wrong - everyone told me the turbo should work fine.....
Daniel wrote:It looks as though it will work fine. Should have much more lag than standard. at what rpm do you reach full boost?
I suspect it has a .5 bar actuator. You should look at getting a boost controller, a manual bleed valve should work fine.
It kicks in very very late, at about 5000rpm it starts to gain boost - the actuator is adjustable. I have no idea why the turbo is'nt boosting sooner - everyone told me it would work fine. I'm clueless. this was the only turbo that mr. turbo stock that would fit my standard exhaust outlet.
Daniel wrote:5k rpm holy smokes. is it possible to check if the wastegate is stuck open?
Wastegate is properly closed with some tension on the actuator keeping it shut. it came to me as a shock when I drove it today and there was no power. verry dissapointed after all the labour....
