Shogun, +700bhp ca18det
shogun
Post by shogun »
Good feeling :)
shogun
Post by shogun »
It has been rather unclear what ARP-studs to use for the main bearing caps on the ca18det. I made an extensive investigation and can now confirm that the kit 165-5402 is a 100% fit.
shogun
Post by shogun »
Thanks to blue redtop, the engine starts looking very shiny. You can tell he is very good at polishing aluminum. Thanks again blue redtop, I am 100% satisfied with your work. You will recieve some more work orders from me soon.
shogun
Post by shogun »
Some minor things I did to improve the handling ;)
shogun
Post by shogun »
Got a Seibon hood and I must say it is the best CF quality I have seen so far.
Judge for yourself.
shogun
Post by shogun »
Some pictures from the garage
shogun
Post by shogun »
and some past summer ones
shogun
Post by shogun »
shogun
Post by shogun »
Upgrading the brakes.
Front 350z track edition discs and Z32 calipers.
Rear Z32 discs and calipers.
Bolt on.
shogun
Post by shogun »
This is how I rebuilt a Z32 gearbox to fit my car (200sx S13 with ca18det).
The good thing about it is that you can reuse the nice clutch you already invested in for your S13. I have a twin disc OS Giken clutch, bought for my S13 gearbox. Both gearboxes have the same dimensions on the ingoing splined shaft, release bearing, sleave etc. This makes it an absolute fit. The gear ratio is slightly higher. My car had before a top speed of 282km/h at 7800rpm. With the ratio of the Z32 gearbox and new tyres it will make aprox. 305km/h. Hope you like it.
Clutch: Same as S13 (clutch, bearing, release sleave, starter motor, flywheel)
Weight: A bit heavier because of internal dimensions
Length: A bit shorter (reuse the yoke from the Z32 and the rear part from theS13 and make a new, longer prop shaft)
Gear ratio: A bit higher (~5%)
Shift stick: Reuse the one from Z32 or buy a new short shift
Welding in cast aluminium: You need a TIG or go to a welding shop (sand blast the weld area to make it clean and easier to weld)
Z32 original gearbox from a Twin Turbo 1994
Disassemble the clutch housing (Z32)
Parts to remove to disassemble the clutch housing. Not shown are the screws on the outside (remove), attaching the cluth housing to the gearbox.
Remove all screws around the cover and carefully lift it off
Remove both snap rings and the stopper ring
Be careful not to lose any important washers or shims
Important! First remove the screw, spring and ball before removing the complete interlock assembly, the ball might fall into the gearbox.
Before you disassemble the clutch housing of the S13 gearbox, you have to make a centering device. Use a plexi glass plate (10mm) and drill a 16mm hole in the centre, put the plate over the shaft (snug fit) and carefully drill 4 small holes exactly in the centre of the holes where the gearbox is attached to the motor. Remove the plate and carefully drill the holes just as big to get the screws in
Result
Remove the clutch housing from the ca18det S13 gearbox. It is more or less just to remove the screws on the outside of the clutch housing, remove the cover and one snap ring.
Remove the snap ring under the cover
Comparision between the both gearboxes. One is useless over 350-400Bhp, the other last well over 1000Bhp and more.
Use an angle cutting machine and cut off the flange from the S13 gearbox ca. 50mm, take it to a machine shop and have it grinded down to 45mm. Important to get it absolutely flat and equal all around.
Use an angle cutting machine and cut off the flange from the Z32 gearbox ca. 40mm, throw away the flange and take the rest of the clutch housing to a machine shop and have it grinded down to 355mm. Important to get it absolutely flat and equal all around.
Both parts after grinding, cleaning and reattaching the clutch housing on the Z32 gearbox
Put the S13 flange snug to the Z32 clutch housing and attach the centering plate with four screws
Side view
Top view. Important to align and rotate them like on the picture
If you do not own a TIG-welding machine, you go to the machine shop again and have it carefully welded together, both from the outside and the inside
Reuse the shift stick bracket from the Z32 gearbox. You have to cut out some small triangles from it, bend it to a Z-shape to fit the S13 under body and then weld the cut outs together. (borrowed picture)
The new short shift
A small change of shift stick position compared to the original (borrowed picture)
A plate to cover the hole at the shift stick (borrowed picture)
A bracket to hold the gearbox in place (borrowed picture)
Aligning the gearbox with the rear axle. Put a steel tube in the gearbox, aim it towards the centre of the rear axle flange and find the final position of the gearbox bracket. (borrowed picture)
Side view (borrowed picture)
Front view (borrowed picture)
The prop shaft. Mount the Z32 yoke in the gearbox and the original flange on the rear axle. Measure the centre distance between the loops in the yoke and in the rear flange. Use this measure and go to your local prop shaft supplier and have him to make your new prop shaft. The shaft rotate at about 10.000rpm at max speed so it has to be dimensioned for the forces and also balanced.
shogun
Post by shogun »
Ooops! What has happened here? Time to get rid of the 12 year old styling and renew it. This bumper is now ditched
The new bumper from Image
shogun
Post by shogun »
Some pictures from today. Jay has done a marvelous job on the shiny bits. It is nice to assemble clean parts :D
shogun
Post by shogun »
Device to correct the speedometer. Needed because of the different speed signals and gear ratio in the Z32 gearbox. It also handle changed wheel/tyre sizes etc. The sensor signal to the speedometer is handled to show the correct speed on the speedo. It also show the max speed from the latest run by pressing a button.
shogun
Post by shogun »
A toy I built some years ago. Had 1136BHP to play with and made mid eights on the quarter
I had lots of fun with it and did heavy modifications on it to gain power and reduce weight. Now it is back in the states again and in the hands of a very happy owner. Last I heard about it was that it made great times on the strip and has won quite a lot.
shogun
Post by shogun »
[QUOTE=rogoman;1291430]Nice set of pictures. How about some detailed specs of the ca18det?[/QUOTE]
Thanxs!
Yes, you are right. It is about time so here we go:
* Blueprinted custom engine with everything exchanged for maximum HP and durability
* Custom made JE Forged Piston; High Heat Ceramic Coated crowns and Moly coated skirts, Heavy Duty Wrist Pins, Contact Reduction Grooves, Total-Seal Gapless Top rings and more
* Pauter Forged 4340 Con Rods
* Full flow ported head, polished valves and multi angle valve seats
* Tomei Procams with adjustable cam wheels
* Tomei valve springs to match the lift and duration
* Trust reinforced cam belt
* SRX700 custom design and built flow optimized turbo
* ARP head, main, rods, flywheel studs/bolts
* Custom made exhaust manifold and down pipe
* ACL Performance bearings - Calico coated (rods/main)
* OS Giken Twin Plate clutch and Z32 custom gearbox, short shift, custom made drive shaft from Spalding, designed for +10,000 rpm
* DTA Fast S60 Pro, fully programmable engine control system with launch control, traction control, ALS, multi maps etc
* 960 cc high Ohm 7-beam race-injectors from Bosch Motorsports development department
* Custom Rail from Nuke Performance
* MAP/MAT-sensors to measure pressure and temperature in the plenum
* 4" downpipe + 3" exhaust system
* ATS Deftforce 1.5-way LSD
* Custom made FMIC from Racecooling
* Q45 80mm TB, match ported
* Custom Plenum, flow adjusted with funnels and developed in flow bench, match ported
* HKS SSQV
* Custom made radiator from Racecooling
* 25-row oil cooler from Setrab
* Upgraded, new oil pump with higher oil pressure
* Double electric fans, controlled by the DTA-system
* Samco silicone hoses
* Light aluminium belt wheels
* Undersize Powerbond harmonic balancer
* Peak Performance engine and gearbox mounts with exchangeable bushings for street & strip
* Aluminium coolant tank
* Air panels to guide the cooling air
* Fuel pressure regulator and filter from Aeromotive
* Bosch fuel pumps
...and on…
