What may transpire...
Ok took the car out for a long drive today. Testing it out. Goes smooooth xept for gear changes when the car is parked and i engage either reverse or drive thers a clunk dont kno what it could be. Any ideas? Mounting maybe? If so whereTF am i spose to get 1 lol? And she also shudders at the steering wheel alot under braking. She has a wrong offset rim on 1 side at the rear and allignment off. Could this be the cause?
Swap the g'box? Not entirely sure but I'm pretty certain you can bolt up a normal SR20DET manual gearbox to the engine, for the swap you will need:
- Manual gearbox
- Manual gearstick
- clutch and brake pedal
- Clutch Master and slave cylinder
- Clutch lines
I have heard that people have done the auto to manual swap on s14's and s13's without changing the main ECU, so it would probably be the same case with the S15
- Manual gearbox
- Manual gearstick
- Clutch lines
- Real Name: Renier
- Manual gearbox sr20det from s13/14
- Manual gearstick
- clutch pedal s13 needs a spacer s14 strait fit brake pedal easy jus cut dow to size with grinder
- Clutch Master and slave cylinder can use s13/s14 use the same as clutch pedal
- Clutch lines
-s13/s14 sr20det flywheel and clutch
-s13/s14 sr20det flywheel bolts
-s13/s14 gearbox bolts
-gearbox crosmember and mounting
-drive shaft
- Manual gearstick
- Clutch lines
-drive shaft
- rat
- Real Name: Rat
Sounds about right but wow what a listNIZAN-R wrote:- Manual gearbox sr20det from s13/14
- Manual gearstick
- Clutch lines
-drive shaft
Ok picking up slowly but url kno of any good guys in dbn who can sincerely do this for me. Cape n jhb too far for me and id like someone experienced not some high named vw tuner whos done 100s of auto to manuals but doesnt kno the 'anatomy' of the sx as im not lookin to hv the car b used as a trial n error thing... If url kno what i mean. Contact numbers of ppl who can do it would help cheers
