Posted: Fri Nov 05, 2010 11:55 am
replace the VTC gear from andre_sx no more rattling sound from the head anymore^^
https://forum.sxoc.co.za/
i have replace the piston with high compression 9.0:1 piston from SR20 VVL for now because my block still measure at factory spec... just to see what difference do they make... i have custom order 88mm piston with the same compression from JE piston to go on the Eagle rods, now just waiting for them to arriveAdrian wrote:hey aep are u gna replace the pistons??
parts are looking good
what do you mean?Captian wrote:So what wing are you going to put on, if any?
i am getting the HKS 85mm system...^^ nur-spec have to go soonRiekert wrote:Looking awesome! and thanx for the parts
Really Really like the exhaust system your running there!
mmm... lemme know... I might be able to make it fit the S13aep886 wrote:i am getting the HKS 85mm system...^^ nur-spec have to go soonRiekert wrote:Looking awesome! and thanx for the parts
thanx man^^ yes one thing i just find out... the mechinic used some oil he got in those 200l drum... i still have the Shell helix oil...^^ as he said use shit oil to run inantman wrote:Very nice rebuild...just a caution IMHO...the fully synthetic not a good oil to use as a running in oil. New parts will not "bed in" properly. Rather use a good mineral oil for the first couple of thousand kms and then switch to a synthetic.
A very nice car you have sir.
