Dicktator wasted spark help
THEO 3K - ZN
Post by THEO 3K - ZN »
who dyno tuned the car?
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
poizen
Real Name: Mical Mackay
Post by poizen »
abc motorsport/speedshop ahmed dyned it
THEO 3K - ZN
poizen wrote:yip
227.5 BHP
and 272nm on the wheels it feels awesome
170kw @ the wheels? What boost?
You using your big injectors?
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
QUEENSBURGH TRADING
poizen
Post by poizen »
o.85bar boost std injectors aftermarket fpr set to 2.5bar with vacuum and walbro pump
n1smo200sx
Post by n1smo200sx »
I think maybe its flywheel power,stock injectors can't go that far IMO.
My SR on stock injectors,walbro made 162rwkw on 100% cycle with bigger turbo on 0.6bar.
If it did that power than the FP must very high.
Also that is on a stock turbo which is unlikely.
poizen
Post by poizen »
its not stock turbo its t3t4
poizen
Post by poizen »
they said my injectors wernt handeling like stock injectors he said on idle stock take 1.4-1.5miliseconds and mine were on 1.1miliseconds but as far as i know they are stock
Doesnt matter what turbo, stock injectors simply cant supply enough fuel for that power. If you had a HUGE turbo you would make that power at 0.3bar, the fuel is what limits you.
Either the dyno is fibbing or that is corrected to flywheel power.
n1smo200sx
Good power then-get some 550's and boost it 1 bar.
Should make 200 easy.
andre_sx
Post by andre_sx »
its all about getting the equalibrium my SR made 180rwkw on 0.9 with import single BB Turbo t28 standard injectors walbro pump o and about 98 octane
djtreble
Post by djtreble »
That power is achievable at a big stretch but only at 1bar +...but you will be REALLY stretching injectors and the t25 (if that's what you are running).
You can run that power at the fly on a safe stage 1 tune here (filter, free flow exhaust, 1 bar boost, higher octane fuel 97RON, optional FMIC)
Things won't last long though
www.rotawheels.co.za
www.kaihatsu.co.za
poizen
Post by poizen »
well i was told wheel who knows i aint no expert in this field
my afr are nice running in the 11s with full boost
poizen
Post by poizen »
again not stock turbo dj its t3t4
ok here my mods
t3t4 turbo
76mm zorst
600x300x76mm fmic
std injectors
aftermarket fpr set to 2.5bar with vacum
walbro high flow pump
and boost set to 0.85bar
warn rings
slight oil leak
258-000km
n1smo200sx
Jip-remember it was with a very good and very expensive MINEs tune AND BB turbo!
djtreble
Post by djtreble »
Poizen, I think it's achievable at the wheels buy the injectors will be MAXXED! I'd upgrade asap because you are risking damaging your engine.
www.kaihatsu.co.za
