Max Revs??
Post by Vlade »
Solid lifters is a big change Tomei recomends changing the following for it
Cams
Valves
Springs
Retainters
and of course Lifters
See the problem is if you stick with your normal cams the engine will be hella noisy, you might experience other problems as well.
Check below to see why they say you need to change your cams
On the right a solid lifter (Roller cam), left normal cam... check at the pitch of the lobe, its rounder to avoid the bounce, once the cam pushed the lifter down, an hydraulic softens the bounce.
The KAK thing with soild rocker lifters is if they do get noises you gotta reset the tappets. This guy that did them, it came as a kit but was off another OEM car. I got the guys details if you want to speak to him.
Post by Vlade »
RB engine's run solid lifters from the factory (RB26TT)... I'm not sure about the others though.
RB26 does, but not the other RB's!!!
have you seen the video of the ultimate response R34. that thing is never below 4500, and instantly revs to about 9500/10 000rpm.
i mean almost instantly - in each gear. just like its first gear.
looks awesome!!! i want one!
The Calibrator
Post by The Calibrator »
Converting to solid lifter will not make your car rev any higher.
You have to change the cam profile as well to enable the engine to make power at that kind of rpm.
if yr car is making peak power at 6 or 6500 why rev it to 9?
ChemCool
Post by ChemCool »
Common guys - listen up and listen to what calibrator is saying(said twice). :P :P :P :P :P
COOLER, FASTER, LIGHTER
The Calibrator wrote:It pointless changing at 6 if yr max power is there as you will be dropping off your torque curve in the next gear.
Thats the reason u say the car went better when u revved it till 7.
actually - first he said that... then he said this:
The Calibrator wrote:if yr car is making peak power at 6 or 6500 why rev it to 9?
bit of a contradiction in terms.
what is it then? rev past the power/torque peak, or not?
The Calibrator
Its not a contradiction in terms at all.
Its a fact that you have to rev yr car past the peak power point HOWEVER there is no point in revving to 9 if the peak power point is at 6 or 7 thousand as the power drop off will be substantial.
If you try and rev your stock ca18 to 9000 it will probably make less power than it does at 2000rpm.
If this doesnt make sense I suggest some study of dyno graphs with particular emphasis as to what happens to the shape of the curve after peak power.
The Calibrator wrote: If you try and rev your stock ca18 to 9000 it will probably make less power than it does at 2000rpm.
LOL - i must've misunderstood something. and yeah it was late.
i do understand the peak and dropoff principle!
Post by Vlade »
I guess what the man is trying to say is
If your peak is at 6000 a good shifting point would be at 7000 if your RPM drops off a 1000 when shifting... there is no need go beyond that? Point.
Converting to a solid lifter setup isn't going to help at all like Duane said, I took for granted in my post that the cam your changing too, would have longer duration and higher lift :wink:
I personally rarely look at my rev counter when shifting, if you have to ask me where my Polo's peak exact peak power sit I'll guess 4500rpm, i'm not sure, I concentrate on my driving rather than staring at a dial... after a while you "feel" the car, sound and torque play big roles... But yeah I can honestly say I can't do this in my SX, haven't been driving it nearly enough, with the new engine its gonna change anyway I felt it with the first build attempt. And to say also I don't drag race :roll:
Ok I've been talking enough kak for one night, I'm about a drink ahead, and 2 hours behind in sleep :wink:
Sokar
1.0 Bar Boost
Post by Sokar »
Vlade wrote: unlike tin can brother the SR, which needs rocker stoppers
Play nice :P .... We dont need to rev, our cars just give lumps of torque all the way to 6500.....
veecee wrote:and the story about the SR's floating valves at high rpm??? is that a sales pitch to move those SR rocker arm plate thingy's, or does it really happen???
the reason i ask is that i've read plenty that you need to buy those things!
I've heard them too, I think the N/A ones can rev high???
Captain Slow to the rescue!
Yes that is true but hydraulic lifters are no good for high reving cars. They will cause valve bounce, and hence the peak power is lower than it could be. With the change to solid lifters the motor will not experiance as much valve bounce and therefore more power can be made.
Dislex666
Post by Dislex666 »
warre hell??
my car revs till like 7500+ and it's happy with that :D
