Project Pure Porn S14
- phoenix s14
- Real Name: Mark Appelgryn
LIttle update... still no boost... yet
Well bigger TB was always on the list and will soon be fitted (THANX PFB)
Also I am nearly there with the funding I need for a new turbo. The old one will come off and in its place a GT28. Wish I had the $$$ for a ball bearing turbo but sadly I don't. I promised some pics and I will have some soon.
- phoenix s14
Well the GT28 is coming today. Having a friend do the pickup and I will get it from him later. Should have water ports as well so will be doing some nice braided line for that (have 1 need to get 1 more).
Will post some pics as promised as I fit it. Will post the other pics along with those also.
- phoenix s14
Re: Project Pure Porn S14
Haven't posted here in a while since there was nothing to say but the turbo came loose... AGAIN... anyway spent last weekend fixing that and now won't do it again.
Tuning is coming along nicely and the GT28 is spooling quite well now thanks to some further mods which include:
- BIGGER TB off a SR20VE - 60mm (Thanks again PFB).
- DE cams and new rockers from a highport head I bought.
- Heat wrapping the exhaust manifold.
- Porting and flowing the exhaust housing on the GT28 to match the manifold.
Coming this month:
- New airfilter to replace the stock paper one - probably K&N replacement filter
- Some ducting and velocity stacks for sorting CAI
Coming this month:
- 0.9 Bar Boost
- Real Name: ????
My turbo also kept coming lose, the guys at the zorst place didn't make a bracket at the middle of it so the weight was on turbo have a lot if you have the same problem.
- phoenix s14
exhaust has a bracket in the middle and lots of hangers too and the only weight from it on the turbo is from the flexi forward (so just the down pipe). I can honestly say that I do not know why it keeps coming loose. Had everything from locking nuts etc etc etc. But wont come loose again until I want to take it off.
Next is the intake and some more tuning. The Nistune board is becoming the best investment ever. nearly there with the tune. Car is nice and smooth but I need to start optimizing for a bit more power. breaking traction @ 0.6 already is fun but upping the boost is becoming the next step quickly. next stop - 0.8bar optimized and then 1bar... hoping I can get to the next goal without another set back...
Nearly abandoned this project and sold it but came to my senses... need some results now though.
160-170KW ATW @ 0.6BAR - Since I got 140KW this is the next step.
Then
180-190KW ATW @ 0.8BAR
Lastly
200-220KW ATW @ 1BAR - After fueling upgrade (injectors, FPR and possibly fuel pump)
Then
Lastly
- 0.9 Bar Boost
- Real Name: ????
Try making a bracket from the down pipe to the box standard ca zorst system is like that or atlest mine was
- phoenix s14
Small update...
Stripped out the interior for some sound deadening. This is stage 1 next will be the whole boot compartment and full redo of the boot lining panels etc...
- mario_200sx
Your doing it wrong! Your suppose to take stuff out! haha
- phoenix s14
Bought 2 from autostyle. They where R195 each
- phoenix s14
Small update...
Seems like I finally got the boost controller working... just goto get the curves right so it does not fall away.
Got it set on 0.8 and 1.0 bar. But dropping to 0.7 and 0.9 so just need to play with the curves a bit. Got some det at 1.0bar though. Need to play a bit with the maps but I will need to change the injectors I think.
