custom parts?
Wanted or for sale
angelo wrote:Alot of guys want wheel spacers.
Make a price on the wheel spacers.
cheers
ditto. even if they do break and I kill myself... just wont state where I got them :P
poizen
Real Name: Mical Mackay
Post by poizen »
cheers
well bud if you dead doubt youll be stating anything really
ok ill do spacers i know they wont break as ive trused my life with them
but i cant help if a guy doesnt install them correctly then trys to sue me
ill make you sign a consent first hahah
Lindt
Post by Lindt »
might need some 5mm 5x114 spacers, I don't like those multihole cheap poo one get. it's just to get my wheel to clear my caliper
poizen
Post by poizen »
Lindt wrote:might need some 5mm 5x114 spacers, I don't like those multihole cheap poo one get. it's just to get my wheel to clear my caliper
as long as your wheel studs are long enough min id make is 20mm unles you have longer studs to do thru 5-8mm
Lindt
Post by Lindt »
I have 10mm longer studs in mine, bought new 5lug hubs from ichiba with longer studs, wish I could have my hubs made from alloy, might cost a bundle but the weight saving will be a lot
poizen
Post by poizen »
Lindt wrote:I have 10mm longer studs in mine, bought new 5lug hubs from ichiba with longer studs, wish I could have my hubs made from alloy, might cost a bundle but the weight saving will be a lot
i could make them out of aircraft aluminium but not sure if the read splines would hold ok then 5mmor 8mm spacers will work fine on yours
T6061 is what they generally use for spacers. I can only ever find 6082 & 7075.
I heard 6082 is just as strong as 7075 though.
A mate made a belhousing to fit his Nissan A15 motor to his beetle box out of 6082, its working a treat. And its just the bellhousing holding the engine in place.
The rear hubs might be tricky seeing that the hub and bearing are one in the same thing. And its a bit of a biatch to find any bearing that is almost the right size and right spec.
poizen
Post by poizen »
they have been machined befor so i can copy them just need sample and can chande the design so it can hold a more common bearing
poizen wrote:they have been machined befor so i can copy them just need sample and can chande the design so it can hold a more common bearing
Would be great if you can.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
could you giv us a rough price on the spacers by any chance?
Current. CA18DET S13
poizen
Post by poizen »
nirvash wrote:could you giv us a rough price on the spacers by any chance?
hmmmm depends on material
if it standard aluminium prob 300-400 per spacer might be more not sure of the cost of material
What grade ali do you use?
poizen
Post by poizen »
you asking me hahhaha just normal for my spacers as there is no load on them
No I wasnt asking what should you use, I asked what would you use??
There is loading on them if they studs are pulled into the back of them, or do you just turn longer studs that go through the hub and through the spacer??
Locked
