Another update... should probably just post the lot
Any way... Took it for a spin when we got it running... literately
First I beached it....
Took it on the road, spun it around, to get back in the complex
looking dirty...
Rear is still high, front is just unpractical low, can't get in or out of our complex without scraping the chassis on the ground, there is no way I'm gonna get around with a bumper on... Will need to make a plan... maybe cement up the driveway one night with some quick set cement
I had to raise the car as it was just too low... 10mm didn't cut it
tires were still touching body, had to raise it a total of 14mm, tires will still hit the wheel well under a hard corner, but I'll live with it.
So this is how it looks now... Not very happy about the look, maybe some spacers will make it look moar flush
Took a hammer to the body, so it won't touch under some load
How Willie temporarily mended the exhaust... africa style... going to get an joint inserted there
Installed some fans... I really wanted to use the ECU's functionality to turn them on, but the harness has no pin for the auxiliary fan switch
and a couple of failed attempts to pull out a pin from some unused wires failed, and I wasn't even sure if the ECU was programmed to switch an auxiliary fan, so I made the most of the old AT override switches.
Did a whole lot of misc shit, like getting the speedo running, engine temp, wipers... takes allot of freaking time.
Safty loops are in... hope it satisfy's the certifiers, if it doesn't meh... will redo it with slightly thicker flatbar (its a rule here in NZ, when you do engine upgrade you need safety loops)
Its got a bonnet now (well it had for the last few weeks, but only fitted last weekend). HID's working again, dunno what was wrong, but upgraded fuses to 35A per channel.
Took apart the cluster to see whats going on in there. As I need to get my rev counter to work on the 6. There is an adjustable POT (Potentiometer), so my guess is that with the right tools (an automotive analyser) I'll be able to recalibrate it. I think..
My Inspiration
It's nearly done bitches...
Some more misc photos
My mates car parked in my garage we fixed it up for him while he was on holiday
Long story short, after 6 weeks of getting grilled by NZ Transport Authority I got my car road legal and can now drive it around... Car has been on the road for 2 months now, its an absolute dream to drive, so much direct feedback.
Being more a race car than an actual road car, it lacks the basics like heaters/cooling/aircon/rear seats/sound damping so its loud, its hard but I always wanted something like this... even if it looks scrappy, I'll eventually paint it, if I don't sell it before then.
