Ca18det spluttering or hesitating when I accelerate
Richard
Post by Richard »
Have not had time to check the car yet, however I will use your suggestions and try everything and let your'll know what happens
Verdict?
Richard
Post by Richard »
Howzit, checked all, points to power transistor, not 100% sure though.
Does it still do it....or should I say...did it still do it...
Richard
Post by Richard »
Yes it does, hadn't had time to strip stuff and check properly.
Had a similar problem on mine. Turned out the cable from the ECU that runs the fuel pump was damaged. Only found out after I dropped in a new motor :oops:
THEO 3K - ZN
Post by THEO 3K - ZN »
I had a similar prob, change the plugs
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
POWDER
Real Name: Mike
Post by POWDER »
try checking some of the following items, vacume lines, coil packs, cas. those used to give me endless issues.
initially i had a faulty cas, had to keep advancing every now n then.
then had a stuffed coil pack, replaced and 13 went like a dream again.
the vacume line on the manifold then kept on making me think i had a stuffed coil again every now n then.
all or one of these can cause the problem ur experiancing.
let us know what the actual prob. is though...
Richard
Post by Richard »
Thanks for help guys, will try and let your'll know.
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
Sounds like it running very lean :?
Richard
Post by Richard »
Actually it's running very rich, strong fuel smell when idling and only gives me about 350km's to a tank.
I've done a complete service, changed plugs and oil etc.
Checked following items.
afm - fine
coils - fine
cleaned and replaced o-rings on injecters
checked vacume lines - fine
cas - fine
power transistor - reconditioned (I hope they did not screw it up)
Replaced AAC valve
Wiring could be a problem, my idle becomes a bit unstable when I fiddle around with some wiring, need to strip and test.
Spoke to Ads from the website, I might ask him to check stuff out, he has helped me a few times. Time is a problem, don't have enough of it.
afm - fine
coils - fine
cas - fine
Replaced AAC valve
Interesting... :?
afm - fine
coils - fine
cas - fine
Replaced AAC valve
Interesting... :?
+1
Cleaned your AFM?
mario_200sx
Post by mario_200sx »
Spark plugs? Do you have the correct heat range installed?
Pinkfluffybunnys
Real Name: Ashley
afm - fine
coils - fine
cas - fine
Replaced AAC valve
Interesting Keep us posted
