Re: Overfueling Issues Ca18det
Posted: Fri Mar 08, 2013 9:41 am
I'm pretty sure that is a narrow band lambda? not great for measuring AFR's.
If I recall correctly from the manual base fuel pressure should be set to 36psi, best to check the manual though as its quite a procedure you need to follow.
