Posted: Thu Jun 25, 2009 9:41 am
				you in roodepoort, you can stop here by my work on friday about 4pm then i will show you how to do it. im in 13 nickel str technicon roodepoort
https://forum.sxoc.co.za/
Thanks I think Ill come throughhentiebez wrote:you in roodepoort, you can stop here by my work on friday about 4pm then i will show you how to do it. im in 13 nickel str technicon roodepoort
You can adjust the pin under the drivers side for a high clutch or low clutch.Charlvdw wrote:You cant adjust the pin i think you might need to replace the seals.
I thought you ment the one on the slave cylinder, dont think adjusting your paddle hight will solve your problem. Im talking about the slave and master cylinder seals. Bad idea for now cause youll need the car saterday.Drillergy wrote:You can adjust the pin under the drivers side for a high clutch or low clutch.Charlvdw wrote:You cant adjust the pin i think you might need to replace the seals.
What seals you refering to?
Yep but its fine, Ill make a plan.Charlvdw wrote:I thought you ment the one on the slave cylinder, dont think adjusting your paddle hight will solve your problem. Im talking about the slave and master cylinder seals. Bad idea for now cause youll need the car saterday.Drillergy wrote:You can adjust the pin under the drivers side for a high clutch or low clutch.Charlvdw wrote:You cant adjust the pin i think you might need to replace the seals.
Damn all the bolts are stripped on the gbox.Charlvdw wrote:Youll need to get the old gearbox oil out and replace it.
I think Ill send it to my Mech to do, this is outta my leagueveecee wrote:remove the front section of propshaft and jack the front of the car up - that will get 95% of the old oil out!
once the prop is back in, fill it through the gearstick hole!
