Timing Issues - Help
I get what your saying and I do agree but I know the timing mark on the Crank pulley and sprocket are correct, I have manual checked them and checked the reference with the pulley on and the sprocket lined up.if it were me, i would only be 100% if i could see the bottom sprocket, but thats a big mission!
I really think its something with the cams, I mean I have done timing on the CA18 about 30 times and I have never had this shit.
But unrelated I am looking over the logged data and there is some interesting stuff here
Guy
So the CAS spline is advanced in the exhaust cam, could this possibly be to allow you to retard the exhaust cam with a vernier pulley and still have some adjustment on the CAS? But it doesn't make sense that the CAS is outside of its normal range with the cam set to standard.
To me it sounds like a manufacturing issue with the cam, it may not have been indexed correctly when the CAS spline was formed.
Perhaps a custom CAS mount is required? One that does away with the front cover.
Exactly what I was thinking but why would an amazing company like tomei make such a basic mistake, But anyway I got the CAS to 15 Degrees on the stock cover. The lowest number it can go now is 10 Degrees fully retarded, 15 is just off the stopper .So the CAS spline is advanced in the exhaust cam, could this possibly be to allow you to retard the exhaust cam with a vernier pulley and still have some adjustment on the CAS? But it doesn't make sense that the CAS is outside of its normal range with the cam set to standard.
But for sure the spline is not in the same place as the stock exhaust cam
OK let me start from the top, Idle Vacuum has increased from .48 bar to .54 bar, My Idle speed has increase to 1100RPm this was set back down to 900RpmPlease do share.
Car starts easier possible increased compression? At Idle the MAF voltage has increase my low and midrange are leaner my top is also leaner and peak boost voltage MAF voltage has increased I need to resize my charts.
Also I have a strange feeling the exhaust flow characteristics have changed my cars doesn’t sound the same
Guy
So basically it sounds as if your engine is now flowing more air, out of interest, is your boost level stiil the same, increased, or decreased?Pinkfluffybunnys wrote: OK let me start from the top, Idle Vacuum has increased from .48 bar to .54 bar, My Idle speed has increase to 1100RPm this was set back down to 900Rpm
Easier starting I would think is easier because of a reduced dynamic compression ratio. High comp na motors normally struggle to turn over.
Howzit, Sorry took my boss for a spin, left the cam timing and used my spare CAS that is off by a toothSo how did you get the timing down to 10 degrees now when you couldnt earlier??
To be honest I havnt really looked, When I do the run home I will checkSo basically it sounds as if your engine is now flowing more air, out of interest, is your boost level stiil the same, increased, or decreased?
It can go both ways, Low comp will also cause hard starting look at a rotor but its normally very high 12 -15.1 comps that have a hard time starting and its normally the starter pulling to many amps and not getting enough rotation the easiest will be to do a comp test when I get a chance I will do this also would like to pull the plugs nowEasier starting I would think is easier because of a reduced dynamic compression ratio. High comp na motors normally struggle to turn over
Nothing Yethave you heard back from the japs yet?
Its a long story, About a damaged CAS that has found a homeHUH, how can your spare CAS be out by a tooth??
this is just a thought, but you did make sure you bought the real deal, you will fall on your back to see what the chinese are making pirate copies of these days.. and a mismatched locating pin is just the sort of shit they are famous for..Exactly what I was thinking but why would an amazing company like tomei make such a basic mistake
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
