Project 200SX - PFB style - BMC DIA
Do it, it gives a nice increaseHow did the XS power split down pipe work ? Noticable differance ? I have 2 for my RB26, still have to fit it, big job.
I dont mind your always well come.Ill take a shot at you with my standard sx , dont give a shit if i loose by miles. I yust like to race. Should i start going to AA meetings now?
Rear Strut brace
I got my hands on a universal strut brace and made it work for the rear struts of the SX
Short Shifter
Bought a short shifter from Ian , Sorry no pictures of the install
Race Cone Filter
I got my hands on a Racing cone filter, Its about twice the size of a normal cone filter and added more filtration area.
NIStune
Well After the installation of the intake manifold and the newly rebuilt motor, The cars started to feel sluggish this was because of the lean fuel mixtures.
The stock Nissan system is amazing and can cope with a lot of punishment and modification but I was pushing it to far so after so searching and help from 300zx I found a great system called nistune.
Wideband
Now I wouldn't recommend Nistune without a wide band to keep a close eye on those mixtures , This unit is supported by Nistune and feeds into the ECU to help with tunning.
Injectors
When I installed the is Nistune system, I was so amazed that I hadn't blown my new motor up the Injector where maxed at at only 6000RPM at 0.5 bar boost.
So I imported a set off Skyline GTR injectors replacing the 370cc with a 440cc injector
Maxima AFM
Also when I got the nistune system I realized the stock CA18DET MAF was maxing out and returning 5.1 volts at 500RPM My first replacment MAF was form a Maxima and was the new 4 pin unit it worked well till it started maxing out aswell with a little boost increase.
New Exhaust system
After years of using my old back-yard 76mm exhaust, I replaced the unit with a 80mm stainless steel Item. I cant even start to explain the workmanship of the item
The mandrel bends help increase power even more.
New Engine bay color.
I changed to color again what can I say.
Z32 AFM
So after struggling with he Maxima unit for some time, I just went an bought a N62 unit. 500hp supported power
Exterior Modifications
I removed the rear wing and installed clean indicators
3 Inch feed pipe
I replace the custom 2.5 inch intake pipe with a 3 inch item made from stainless steel, This eliminated all intake restrictions to the turbo
F1 Stage 3 Clutch
Well after the nistune system the stock copper clutch started slipping, So I just imported a Stage 3 F1 Clutch kit with an exedy pressure plate.
You cant even compare this item to our local cr$p this is the real deal and she grabs hard
Screamer pipe
To help drop back pressure even more, I made a custom screamer. I will not recommend this modification because of the noise when on boost and when off boost.
Old pipe
New Pipe
Brake Upgrade
Well I upgrade my front rotor with a set from Rotor 88 in the states. It works well and was a cheap effective upgrade
Torque Dampener
This Item does work well but I would recommend solid mounts on Nismo mounts to any SX member
Lightened front pulley
To help drop wight even motor, I converted to a FWD pulley and got a little extra wight shaved off.
C-piller bar
This help make the chassis even more rigged
New front strut bar
Replaced the old one
Bracing front Suspension
Short Shifter
Race Cone Filter
NIStune
Wideband
Injectors
Maxima AFM
New Exhaust system
Z32 AFM
3 Inch feed pipe
F1 Stage 3 Clutch
Screamer pipe
Old pipe
New Pipe
Brake Upgrade
Torque Dampener
C-piller bar
New front strut bar
No thanksRiekert wrote:that might be a good thing... then you can get a SX again
Thanks rat, much appreciated.
You Guys are right.
Just happy it wasnt deleted.
So you got a 330d Jon? Damn lucky those are nice cars
I forgot to added a few mods like the Walbro fuel pump and nismo FPR. I will added them tonight to the correct place's
