I thaught the injector would inject less atomized fuel, quite the oppisite is happening.............
I have pics, will download it on monday.....
I can sell my RB25DET injectors if you are interested. 6 x 370cc side feed, very good condition.Pinkfluffybunnys wrote: “IF” RB25SX take my injectors or some one else’s and converts over I’m sure he will sell the fuel rail and the RB25 injectors are high imp also the SR injectors are high imp
yes it will, A pulse is measured in ms's, ms's is time measured for each pulse, the longer the pulse(ms's) the longer the injector injects, altering the flow rate, I would emagine if the fuel pressure dropped to very low it would alter the pattern, as it will any injector.Also will the stream be consistent all the time even when pulsed?
Thanks but there is a bit of a snag, by trying to solve my problems I found that the SR20 and RB injectors are the same and does not fit my rail......RB25SX wrote:I can sell my RB25DET injectors if you are interested. 6 x 370cc side feed, very good condition.Pinkfluffybunnys wrote: “IF” RB25SX take my injectors or some one else’s and converts over I’m sure he will sell the fuel rail and the RB25 injectors are high imp also the SR injectors are high imp
I am not sure I am understanding you right, you speak of rebuilt....the engine has not been rebuilt, I replaced head gasgets....and by saying the incorrect atomized fuel will cause detonation and bad fuel economy.....I would agree with you on fuel economy if it was just one straight jet of fuel, about the detonation....it's as easy as I don't know....there is no info to back that up.Pinkfluffybunnys wrote: the car will run with these injectors and it will boost , It will also feel stronger because its been rebuilt but without the correct atomized fuel its going to det and return bad fuel economy.
No, it has the side feed injector rail, 3 on a side, the Z I have has a different intake manifold than the other models, I have the maxima intake manifold and plenum, if I want to use top feed, I have to find another intake manifold.....and plenum.....Pinkfluffybunnys wrote:Does your car have the barb type injector?
http://www.redz31.net/pages/fuel/fuel.injectors.html
this will happen with any injector.....I am not sure if mine does the same, I just know it pulses with the distrebutor and the management sends the signal, I am sure mine is the same as most old 6 celynders but I think if it handels the setup now it should be able to do it with the rest of the injectors, I already installed the 5 370cc injectors and the one with the broken pintle, runs good but the one injector bothered me so thats where the tests started, if all goes well I will make all 6 injectors the same.I also see another problem that might be specific to your setup, not sure about the stock Z31 ECU or your aftermarket, but if either is firing the injectors in batches of 2 or 3 (common on an older I6 or V6, my stock E30 management was like this) the injectors of the "other" cylinders are going to be firing at 180 or 120/240 degrees of TDC, i.e. against a closed intake valve, forming a nice puddle for when the valve opens.
