CA18det pressure plates?
No, just the bolt holes, the dell pins was made the same size.Speed breeder wrote: If this works brilliant... but then I do need the delpins in the flywheel
Did you increase the size of the delpin and holes on the flywheel as well?
My advice is drill the holes and stuff yourself, it is not rocket science....then take it for balancing.
I am pretty sure you will end up paying less.
Hi Guys
Just fitted a R30MK clutch & pressure plate to my son's SX on Tuesday Night. Car originally belonged to Doctor G.
Just the 1 dowel pin did not align. Since the other 2 dowel pins align properly to centre the plate all it took was to drill an M10 hole for the 3rd pin. No balancing required. However the bolt holes had to be resized as well
Clutch seems to be 100% now.
I am sure my son will register soon and post updates on the car.
Awesome site guys.
Awesome site guys.
- Speed breeder
- 0.7 Bar Boost
