Drifting 101 - for the neewbie
JoKeR**
Post by JoKeR** »
oh ja i remember hearing about that.
thanx
SilviaS13
Club Drifter
Engine: 2JZ
Real Name: Ernest Simpson
Post by SilviaS13 »
Hmmm, back in GP again, saw loads of drifting...ships in the harbour!!!
drifterz do it slideways...
nigelr13
Real Name: Nigel Richardson
Post by nigelr13 »
What bout the drifting in durban, any1 here anything bout that? I havnt seen much happen, or actually nothing infact. Heard all these guys building fast cars and big plans but nothing cums out seems. Hope some1 has more info than i do.
Will Drift For Tires..........
nigelr13 wrote:What bout the drifting in durban, any1 here anything bout that? I havnt seen much happen, or actually nothing infact. Heard all these guys building fast cars and big plans but nothing cums out seems. Hope some1 has more info than i do.
well.. guys that spend big bucks on there cars in Durban are not gonna publicly post where they are 'street' drifting.. now are they.
all im saying is just coz you dont know doesnt mean its not happning... :)
nigelr13
Post by nigelr13 »
Did'nt mean for it to come out bad if that's wat you thought, was just mentioning. Thanks for the reply though.
nigelr13 wrote:Did'nt mean for it to come out bad if that's wat you thought, was just mentioning. Thanks for the reply though.
no probs... :)
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Post by P3g4sus »
hey SilviaS13, why dont you take over the tread? give us some pointers? :wink:
P3g4sus wrote:hey SilviaS13, why dont you take over the tread? give us some pointers? :wink:
x2 ... i agree.. we need a practicing Drifter to give proper advice...
i have a few Q's.. here's number 1 .. :)
After speaking with another NAT Pro drifter from the forum.. he was telling me his suspension setup for high speed comp drifting .. and how it differed from low / mid speed setups. I was amazed at the reverse of suspension ideology.. atleast from what i know.
So i guess my Q to you is.. what are your basic setups for low, mid and high speed drifting. Or do you use one kind a setting for all?
nigelr13
Post by nigelr13 »
Don't be so touchy o, was just mentioning, :D lets keep it clean. Haha :P
ads
Real Name: Adam
drift
Post by ads »
Well it depends on the driver the car and style,
i use a basic setup for any drift,i guess if your drifting at 180km
or drifting at 40kmh then the changes can be significant but usually you drifting between 65kmh-130kmh so i find that minor changes to the damping and spring rate according to the track surface will do.
Then again thats the way i drive, i tend to adjust my driving to the way the car react at high or low speedoing big changes to suspension requires a lot of testing and experiance.
nigelr13
Post by nigelr13 »
So you would you adjust your dampers and spring rate just by trial and error and feel for the track? Also how'd you get your initial setup for camber, caster & toe etc.?
nigelr13 wrote:So you would you adjust your dampers and spring rate just by trial and error and feel for the track? Also how'd you get your initial setup for camber, caster & toe etc.?
Stock setting to start with
ads
Real Name: Adam
DRIFT
Post by ads »
castor i left standerd.as for camber i run as much camber i can get for best front end grip.anything from 3-5 dagrees negative is good.
toe i like to run about 0.5-1 negetive(facing out)on my car that works best and also it gives slightly more steering angle.
damping and spring rate is trial and error at the moment,basicly we trying to stop the car from bouncing in the back,also we trying to make the car more loose at the back because the tires we use are to gripy,you want the car to carry on sliding once you of the power.
cool... so what does your suspension consist of? ie .. coilovers.. complete arm kit .. uprated sway bars... urethane bushes... etc ..?
Also .. do you do your own alignment or do you take it to .. say 'tiger wheel & tyre' and tell them the settings you want .. :)
aep886
Real Name: Davey
Post by aep886 »
get Uras pinapple^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
