You can get it from the Nistune Rom Pack 1.4 just find you MEC numberIs there any way I can get the stock factory map??
They are not even close to the same with regards to timing, the Fuel maps stays close to the same down low but that about it.How much different are these "big name" maps from stock with regards to timing??
From what I have read so far you can’t just shot for a AFR some engines respond better being leaner or richer then for example 11.5 or 12.5, Some guys swear by 11s and some by 10s some by 12s but they all say the most important part is boost transition and peak torque AFR the same is said on the timing frontAlso what AFR do you aim for??
