One Savage project!!! 56k unfriendly
- 200SXSilviaSavage
- 200SXSilviaSavage
- 200SXSilviaSavage
- 200SXSilviaSavage
Hi everyone, sorry I didn't post the pics the other day... Been very busy...
Got the engine back and have been working on it a bit:
Engine with polished tappet covers, not the best work but good for now
The newly sprayed mountings...
The manifold in with copper nuts ( did some sanding of the inside of the manifold cause of all the stuff that was burnt or caked on... the flow should be at least a bit better now
The sprayed pulleys...
Test fitted the turbo using 3 flanges instead of the spacer I bought because there isn't enough space and the compressor housing hits the engine mount...
Getting the oil lines for the turbo tomorrow, so will probably fit the turbo then
- 200SXSilviaSavage
Just want to add info, Changing the compressor side A/R has very little effect on the amount of Air Flow capability a turbo has , Its mainly used as a fine tuning measure but has very little effect over all.
The Turbine Side has a lot of effect over-all on response and power of a given Motor/Turbo combination , For a small example , If you sized that turbo with a .64A/R boost would come on sooner but because of back-pressure the power would be down over all when on boost if compared to using a .86A/R
Anyway Great build up cant wait to see more
- 200SXSilviaSavage
nice - i like the polished covers. brings back old memories!
i remember putting like 10 hours of elbow grease into just one of the covers!!! paint removing, dry sanding, wet sanding, again and again and again, then polishing!
well done!
well done!
- 200SXSilviaSavage
