Page 2 of 2
Posted: Thu Dec 07, 2006 9:39 am
If I knew the wire I was testing was for the flickers I woulden't have used it, but thats how we learn hey, now I know what wire works the flickers
Posted: Thu Dec 07, 2006 11:45 am
by Charl
Ok! nevermind! I can't figure this out and don't want to start earthing and bridging things... I need to see a wiring diagram. its now only conneted to the light switch and doesn't flash with a wiper or indacator or anything for that matter...
I put the live in the connector which is for the lights and indacators etc: It goes in the bottom row and in the very right hand side.(closest to the door) as far right as possible. don't get confuse with bottom right...
and then u just ground the neutral...
Posted: Thu Dec 07, 2006 12:29 pm
Does it still work when you put your brights on?
Posted: Thu Dec 07, 2006 12:40 pm
by johansx
Think I will put a seperate dimmer on mine...
www.electronics123.co.za
Posted: Thu Dec 07, 2006 2:12 pm
by Toby
Mine's connected to the lights. Comes on even on park lights or headlights or brights, so most of the time I will drive with park lights on, which is a good thing. Doesn't blink with indicators, wipers, or phases of the moon. Anyone needs help with the connection, let me know. I can put up a pic of my connection if you want. Also connected my footwell lighting to the lights.
Posted: Thu Dec 07, 2006 2:25 pm
easiest way of doing it in any car is to source the light wire for from the radio din... never had a problem when using that same wire...
Posted: Thu Dec 07, 2006 5:10 pm
by Charl
Derek-son wrote:Does it still work when you put your brights on?
yes 100%
Posted: Fri Dec 08, 2006 9:26 am
This is WAY cool
air-fuel
Posted: Sat Dec 09, 2006 4:31 pm
by Charl
Im going to buy an air to fuel ratio gauge next, but i need a lamda sensor which is not included with the gauge.
Any idea where i can get this and what the price is?
Posted: Sat Dec 09, 2006 5:34 pm
by ChemCool
I bought one from Volksie spares in Pta. About R460=00. Check speed and sound for adverts.
