Rezlo Xmas blow out
S13 exhaust and down pipe will fit the SR20 and CA18 DET.
Only thing you can not use is the SR20 turbo outlet when u have a CA18, and i can not get the CA18 outlet. The S13 system will fit onto a S13 with the SR and you can even use the SR20 split turbo outlet, which means from the back of your turbine housing to the tip of your tail pipe it will all be stainless maderal bent for very high flow.
The SR20 turbo manifold is also a direct fit item with the SR20 in the S13 or S14
http://www.radicool.co.uk
even with shipping it will work out cheaper than getting anything here
Thats funny, because unless they give you quite a serious amount of discount and ship it for free, and pay for you to clear it threw customs, mine are actualy cheaper...widowmaker wrote:http://www.radicool.co.uk
Ero, check your pm's
- Slide 'em Wide
- 0.6 Bar Boost
- Slide 'em Wide
- 0.6 Bar Boost
