Clutch Problems
I agree that there is a problem with your hidrolics, but if your hidrolics does not work because of air or what what....the only influence it will have is that your clutch won't disengage properly, your clutch won't slip, you won't be able to change gears as easely or not at all because your clutch won't disengage.
I bank on 1 of two things, either your setting on your pedal shaft going to the master cylinder is out to far or your pressure plate is to soft to keep you clutch ingaged, I have said it before, if you go for a button clutch or stronger upgraded clutch, a dubbel diafram pressure plate will garentee success, it will work with single but at some stage single will be too soft the handle the powa and it will start to slip.
I know some people are going to disagree, thats fine, lets not start again, this is my opinion and the person needing helps perogitive to follow or not.
Hope you get it sorted soon, whatever is wrong.
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
Thanks for all the info guys.
I'm going to be removing the clutch damper like veecee sugested while I'm working on the clutch. I couldn't find an article in the article sections of this forum but here are some other articles on how to do it for those interested:
http://garage.projectraine.com/content_ ... amper.html
http://www.zeroyon.com/index/content/view/32/47/
Veecee, how easy is it to bend that hard line? I don't wanna stuff it up.
- Trance101
- 0.9 Bar Boost
- Real Name: Ryan
I may just have to go with a double diafram pressure plate if I can't get it to stop slipping.Draco wrote:I bank on 1 of two things, either your setting on your pedal shaft going to the master cylinder is out to far or your pressure plate is to soft to keep you clutch ingaged, I have said it before, if you go for a button clutch or stronger upgraded clutch, a dubbel diafram pressure plate will garentee success, it will work with single but at some stage single will be too soft the handle the powa and it will start to slip.
