Posted: Fri Jun 27, 2008 10:28 am
Ok Here is some more info from a engine rebuild libary.
http://www.aa1car.com/library/map_sensors.htm
HOW A MAP SENSOR WORKS
MAP sensors are called manifold absolute pressure sensors rather than intake vacuum sensors because they measure the difference in pressure between the outside atmosphere and the vacuum level inside the intake manifold.
Ambient air pressure typically varies from 28 to 31 inches of Mercury (Hg) depending on your location and climate conditions. Higher elevations have lower air pressure than areas next to the ocean or someplace like Death Valley, California, which is actually below sea level. In pounds per square inch, the atmosphere exerts 14.7 PSI at sea level on average.
The vacuum inside an engine's intake manifold, by comparison, can range from zero up to 22 inches Hg or more depending on operating conditions. Vacuum at idle is always high and typically ranges from 16 to 20 inches Hg in most vehicles. The highest level of vacuum occurs when decelerating with the throttle closed. The pistons are trying to suck in air but the closed throttle chokes off the air supply creating a high vacuum inside the intake manifold (typically four to five inches Hg higher than at idle). When the throttle is suddenly opened, as when accelerating hard, the engine sucks in a big gulp of air and vacuum plummets to zero. Vacuum then slowly climbs back up as the throttle closes.
The reason why MAP sensors measure pressure differential rather than vacuum alone is because atmospheric pressure changes with the weather and elevation. Since this affects the balance of the air/fuel mixture, the computer needs a way to detect the changes so it can compensate. Some vehicles use a "baro" sensor to measure barometric pressure (that's meteorologist lingo for atmospheric air pressure) and a vacuum sensor connected to the intake manifold to measure intake vacuum. The computer compares the readings, calculates the difference and makes the necessary fuel mixture and timing adjustments. But it's easier to let the MAP sensor measure the difference. On some vehicles, the MAP sensor is also used to check barometric pressure when the ignition is first switched on. This is done as a sort of baseline calibration check.
On turbocharged and supercharged engines, the situation is a little more complicated because under boost there may actually be positive pressure in the intake manifold. But the MAP sensor doesn't care because it just monitors the difference in pressure.
On engines with a "speed-density" electronic fuel injection system, airflow is estimated rather than measured directly with an airflow sensor. The computer looks at the MAP sensor signal along with engine rpm, throttle position, coolant temperature and ambient air temperature to estimate how much air is entering the engine. The computer may also take into account the oxygen sensor rich/lean signal and the position of the EGR valve, too, before making the required air/fuel mixture corrections to keep everything in balance. This approach to fuel management isn't as precise as systems that use a vane or mass airflow sensor to measure actual airflow, but it isn't as complex or as costly either.
Another advantage of speed-density EFI systems is that they are less sensitive to vacuum leaks. Any air that leaks into an engine on the back side an airflow sensor is "un-metered" air and really messes up the fine balance that's needed to maintain an accurate air/fuel mixture. In a speed-density system, the MAP sensor will detect the slight drop in vacuum caused by the air leak and the computer will compensate by adding more fuel.
On many GM engines that have a mass airflow sensor (MAF), a MAP sensor is also used as a backup in case the airflow signal is lost, and to monitor the operation of the EGR valve. No change in the MAP sensor signal when the EGR valve is commanded to open would indicate a problem with the EGR system and set a fault code[/b]
[/img]
