Posted: Mon May 26, 2008 3:28 pm
Hey guys, I mentioned the NISTune setup the other day in the Dicktator thread.
Have a look at the website there, with a daughter board the tuning is real time.
I downloaded the software to have a look at, it allows you to open a trial version that cant change or save anything, but the maps look to be 16x16 for fuel and ignition, and have all the parameters available in the factory tuning. It even has maps for fueling and ignition when knock is detected.
The maps can be scaled to whatever ranges you want and it has common changes from the standard configuration available as drop down boxes. So a simple change to a common larger AFM can be done just by selecting the correct AFM from the drop down box and the software changes the settings to keep the car running the same. It does the same for larger injectors as well.
The software is really quite a small download, have a look at it yourselves.
