making the gotech work with a CA18DET , you are going to have problems
with the coilpacks too.. the gotech pro has only 3 ignition outputs , meaning
you will have to run a wasted spark scheme.. (one coil fireing on combustion stroke, other fireing on exhaust stroke )
this has problems of its own,
because splitting a ignition trigger between two coils means less current to
properly charge the coil, which once again means weak spark at high rpm..
and here's the nice thing about gotech...
i emailed Louis from gotech, he said its no problem to change my gotech pro to the TS version, which has 4 ignition output drivers.
it will also cost nothing to make the change.
all i have to do is take the box in and they will change it for me!
now thats what i call aftersales service!
just thinking now.. if you will be changing for a gotech TS , why sell your coilpacks at all? 4 ignition outputs can trigger your nissan ignitor, so you can use the nissan stock system?
and so we come back to the reason for the existance of this whole thread..
4+1 - 4 holes to indicate cylinder at TDC - and an extra hole as an indication of when cylinder 1 arrives at TDC
oh yes, of course.. sorry
remember that you will need that cyl 1 tdc signal for the ignition too.. so yeah, 4+1 will work, i had my disc cut by an engineering works after making them a 1:1 scale templete.
LOL - this thread lots its point a long time ago, and i will actually be moving it to the tech section!!!
thanks 300, i realised a while back that i wont be selling the coilpacks 1 cos the gotech can handle it, and 2 cos there has been no interest in the damn things.
i dont have a nissan ignitor - but thats ok, cos the gotech can fire the 4 coils directly!!!
all i need now is a custom disc - in comes gary57 stage right!!!
