I was just saying in case you didn't know that... A lot of people don't...
Some people like to know their fly kw's to know how much power his motor makes and then to see how much it looses... this allows you to try different diffs and drive-line, oils etc...
The difference in wkw and fly kw can then be compared to see your losses and gains etc to compare.
How far can you push the Std Management
first of all - boost cut means that SOMEHOW the ECU stops the engine from boosting. unlikely! and fuel cut means that the ECU cuts fuel. totally likely. so its not the same thing.MyPRodOL wrote:@ VEECEE - I know... there is more than one term for that... its referred to as the dreaded boost cut...
Its the same theory, comes down to the same point... o and it can pop your motor.
What happens is... your stock MAF works in VOLTS, meaning certain air flow will calculate to certain VOLTS. If its small sensor it can't read too much air, thats why you fit a bigger sensor like the Z32 etc.
So now you boost.... more than the sensor can read, and it zero's out. the ECU goes into Fuel cut mode as it can't understand the values given from the MAF and that can cause the motor to run lean... which will cause immediate knock, and this can result in a popped motor. As we all know... bad knock can blow a motor in seconds.
This won't always happen, but it can...
second of all - if the computer cuts fuel - that means that no more fuel goes into that cylinder. at all. it will be dry within a cycle i reckon. not so dangerous. not something you want to happen, but not the end of the world.
it would be best if the computer cut spark. safest way, plus you'd get a nice popping banging sound out the back!
- mario_200sx
it doesnt,
maybe yours doesnt boost quick enough before the revs run out in first gear. you have changed the turbo right - you have a 0.64 exhaust housing? that means your boost comes in later than other sx's with T25's.
remember that first is a very short gear, doesnt give you much time before you need to change???
- mario_200sx
i was grasping a bit with the runs out of revs comment!
but the ECU on the ca18det doesnt control boost. so it cant stop the engine from boosting full in one particular gear.
actually - the ECU doesnt even know what gear the car is in at any point in time.
LOL.
LOL.
- THEO 3K - ZN
