What is next for my ride...
looks like my 63mm, but you said that the box has a 76 inlet, so i am lekka confused.
i could be confused because there isnt a nice detailed shot of the pipe going into box...
hmmm, sounds dodgy!
hmmm, sounds dodgy!
he he VC you are right. 63mm. They flared the pipe to the 76mm box.
The guy who fitted it also told me that if I want to do a 76mm normal bend pipe its going to be the same as the 63mm. His explanation was that the bending machines that Noise boys and power flow uses has a maximum bend block or something of 63mm. A bigger pipe like a 76mm will be bent and the bends would be a 63mm. The bending machine reduces the diameter when bent. He said the least restriction you get is from bending a 53mm pipe coz the pipe doesnt really reduce.
Interesting...so all the guys out there with 76 normal bend exhausts...you where fooled. Its the same size as a 63mm..or the bends atleast.
My cazorst had custom made 76mm bends, most places can do them, they might actually have been more than 76mm internally...HancoB wrote:Interesting...so all the guys out there with 76 normal bend exhausts...you where fooled. Its the same size as a 63mm..or the bends atleast.
PS, incl the backbox, how much did you pay?
Captain Slow to the rescue!
thats a decent price.
what sokar is talking about is taking two 76mm normally bent pieces, cutting them up, and using the pieces that still have an internal diameter of 76mm at least.
its not as pretty as mandrel bent pipes - but its effective!
Got my car back today and clutch feels ok!
Still running the clutch in so no hard driving for 500km
It feels so good to have my baby back, and to hear that awesome sound, that burble when jou take your foot off the throttle, that backfire when you change and the ou tannie in her getz pisses her pants next to you, that feeling of power going through your body when the revs pick up and pushes you into your seat!
I want to marry my car!!!!
Nice now since I did my exhaust there is smoke coming out at the back...
When I drive it hard and then stop en let it idle she smokes white! Now the guys at the exhaust shop said thats just the new pipe and backbox burning in...but after a hundred or so KM it should stop!
There is a little leak on my headgasket and the oil is dripping on my turbo downpipe...so it might be oil running down the flex and getting burnt in the hot pipe!
I sure as hell dont want it to be my turbo!
