Page 2 of 4
Posted: Mon Mar 10, 2008 10:17 am
by ChemCool
Earth Wires?
This is a new one. Will keep it it mind. Thanks
Posted: Mon Mar 10, 2008 11:09 am
I had this issue when my deacceleration enleanment maps were out, thats why I asked about the tuning.
Posted: Mon Mar 10, 2008 11:27 am
by Ero_sennin
I have had this happen as well just after purchasing my car, during a hard brake situation, the engine cut out.
My brake pads were quit thin and strangly after replacing them that problem went away.
Any thing is possible on an SX :roll:
Posted: Mon Mar 10, 2008 9:52 pm
hey chem,
i havent driven my car in the last few days because i had this exact problem.
these are the things i checked to sort it out:
1. TPS - i reset the position of the TPS, to make sure that the idle switch is working properly. here's how. unplug the black connector. get your multimeter to read resistance (ohms). use the top two pins to get a measurement. your multiM will either read 1 ohm or 0ohm (i had mine on the 20k setting i think). get that TPS to a point where the reading changes when you move the throttle slightly! tighten it.
2. check earths, specially the engine earth. check as many points as possible. fix any dodgy connections.
3. reset the idling via the throttle butterfly thingy. make sure you do this part when the car is warm - temp gauge near the middle.
4. shoot the timing of the car. get the timing right, to where you want it to be.
5. if the idling has changed at all, reset it again to where it should be.
i did this this evening in less than an hour. before i couldnt drive my car because it would cut out on deceleration everytime. now it settles down to 950rpm idle speed perfectly everytime. the idle drop is gone.
i will see tomorrow morning if the idle searching is still there when it is cold!
hope it helps.
VC
Posted: Mon Mar 10, 2008 10:13 pm
by ChemCool
VC, Thanks. I have done this exactly already, before this reply of yours.
No, no lucky me.
Posted: Tue Mar 11, 2008 8:56 am
maybe its time you brought me some beers and let me look at it???
Posted: Tue Mar 11, 2008 1:13 pm
by ChemCool
And I also had that in mind. That bring beer events type of thing.
VC great, I will be in touch. Most probably week end coming??
Posted: Tue Mar 11, 2008 3:50 pm
well - we'll have to consult my diary there ol' pal!!!!
it can get rather hectic at my place on weekendS!
Posted: Tue Mar 11, 2008 4:11 pm
by ChemCool
So, consult that diary then, Let know a few options. Thanks.
Posted: Thu Mar 13, 2008 3:18 pm
by KimiG
Chem have you checked your F.I.C.D solenoid valve?
If it’s not making 100% connection it could be your problem with the stalling!!
Posted: Thu Mar 13, 2008 3:20 pm
he did the wise...
and threw it in the dustbin.
Posted: Thu Mar 13, 2008 3:25 pm
by ChemCool
It is in the dustbin! And the aac valve is also there in the dustbin.I went the VC route. Which works fine. Just need to sort this idle drop thing out. Also I want to make it clear, that the idle drop is not a mere 200 RPMs drop, no it is a drop of 500 rpms' down to 200 rpms, and then hopefully from there back to default.
Yesterday, I closed the bov completely. For a moment it looked like the bov is not closing in time. I know, my bov is not of the greatest quality on earth. Then I reset the TPS again, but it looks like the bug still persists.
Posted: Thu Mar 13, 2008 3:27 pm
what you doing on sunday???
i reckon i could do with some free beer on sunday morning!!! :lol: :lol: :lol:
Posted: Thu Mar 13, 2008 3:29 pm
by ChemCool
Let s do it. I am in. 10:00 . At your place?
Posted: Thu Mar 13, 2008 3:31 pm
sounds like a perfect time for a beer!
