like i said - just get your engine builders to make some.
its not like its a complicated piece of timing eqiupment, its just an oil squirter.
its basically a brass straw with a bolt in the middle!
CA18DET 200SX squirters wanted
if the suirter aint correct the oil will pi$$ out there too much and the car will run bearings cause the crank will suffer oil starvation.veecee wrote:like i said - just get your engine builders to make some.
Speaking from first hand experience (Unfortunately!)
but i said that the engineer should be able to make one...
i didnt say go look in your garage for an old piece of steel and use a dremel too and drill press???
surely if the engineer can make them, then he should be able to gurantee that they will work???
