The stock one sort of came with one, it wasnt exactly designed to be used like that but it works, not to sure for how long it will last like that, hence why I want to replace it with one of the Audi onesPhinx wrote:Just asking...
Did the management come with a Boost control Solenoid?
Becuase the S-13 has no unit as stock.
Hi-Boost, Low-Boost setup
Because the stock "CA18DET" had no way of measuring boost to my understanding and also had no control solenoid.
It had a direct feed pipe to the turbo actuator calibrated for Stock boost
But it did have a Fuel Pressure solenoid for cold starts
Cool ....
No problem man
Sorry Hotstuff, Im going off topic...
No problem man
Ok acording to the FSM it is the Pressure Regulator Control Selenoid Valve.
(This is starting to seem dodgy and I am sure a few people will have something to say about this, hey Phinx?)
Ok on my car this is connected to the managment and controlls the boost. From Hi to Low, with the so mentioned switch, any way mine is connected up as follows.
Top connector goes to just after turbo on hot boost pipe.
Middel conector goes to the wastegate canister.
Bottom Connector on mine is off. (assuming this goes the the airbox) as this will just bleed off excess air.
Hope this helps. I would actually like to go poking around on someones s14 engine bay to check a few things and compare it to my SR20DET
hey HS,
phinx is incorrect. the s13 ca18det, did have a solenoid to control vacuum. it normally bleeds off into the intake pipe between the AFM and the turbo intake.
the other end of it is usually connected to the FPR via a series of hard pipes and hose connectors that run between the cylinder head and the firewall.
because of the location chosen to source vacuum for the BOV, the original vacuum source for the FPR is no longer being used, and that is why the little pipe between the cylinder head and the firewall is no longer being used.
so your original solenoid is now controlling boost because IT is being controlled by the perfect power unit. the same original solenoid also still has a hose connected with the little connector that is supposed to go into the intake between the AFM and the turbo. so i assume that this must stay there.
as for the way that it is properly setup, it was quite stupid of us not to take note of it, but i forgot about the hi/low setting!!! sorry mate. but i would take note of the way that ero's is setup because his was also done at calibrator. basically it means swopping the middle and rear facing connectors and trying that out.
the stock "CA18DET" had no way of measuring Boost to my understanding and also had no control solenoid.
Because the S-13 has no unit as stock.
I'm sorry If I am sounding Rude, I mean this with "max" respect but I was not arguing that the "Ca18Det" didn't have a pressure control solenoid. I was Arguing that It didn't have a BOOST control solenoid like the S-14 in Stock Form.
I'm sorry but I never though of the solenoid being used in that way.
As to me it seems hillbilly but who am I to talk
So my bad , I cant really Assist ..
Thanks
VC and I had this conversation last night, the CA does have a control solenoid, but no way to measure boost, so you cant ACCURATELY measure boost and bleed off air to the actuator..
The only way I think the good ol' 'bater would have done is bled off air according to RPM (i.e from spool to boost to dropoff) and just bled less for high boost... Not a good way to do it as boost can be effected and not happen when you expect, anyone else got any ideas?
Captain Slow to the rescue!
lol, this is why I said above that this seems dodgy and people are going to respond, I tend to agree tho, somehow it does work, dont ask me how I didnt set it up, but I want to change it for a boost control valve in the near future.
Sokar you are correct with the rpm theory, looking at the maps I noticed that altho I think for the boost control selenoid it would work the same.
