Running out of water - WARNING system.
ChemCool
Post by ChemCool »
I like this, and I want that
Chem 8)
COOLER, FASTER, LIGHTER
johansx
Post by johansx »
MadMan EMS Pricing in ZAR excl Vat October 2008
Recommed Retail Price Johannesburg RSA
MADMAN Products Including Vat
EMS1 Rectangular 1846.80
EMS2 Square 1430.70
EGT Probe 100mm + 2m lead 262.20
EGT Probe 30mm + 2m lead 262.20
Land Rover Td5 EGT plate Tapped for EGT probe 57.00
Land Rover Tdi EGT Plate Tapped for EGT probe 27.00
Land Rover Td5 Coolant Adapter Tapped for Temp sender 136.80
Land Rover Td5 Sump plug adapter Tapped Sump plug for oil temp 57.00
Land Rover LT230 Tapped Sump plug for oil temp 57.00
Due Soon - MadMan CLD Coolant Level Detector TBA
Buy-In Stock
VDO Pressure Sender 360/081/029/012 433.20
VDO Temperature sender 323/801/009/001 91.20
Oil Pressure Tee piece 1/8 NPT Running Tee 557.00
Coolant Level Sensor Drill 2 x 1mm hole 273.60
Float Switch RS # 3389744 Drill 22mm hole 273.60
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
The level meter in the water bottle is not foolproof though. In my case, where a radiator hose blew (sounded like a stone hit the underside of the car), there was still water in the water bottle as I continued to drive. I'd be happier if the sensor could detect:
FFFLLLLOOOOOWWWWWW
of water :-)
The Madman thing does look good but I have most of those gauges in the car except oil pressure and temp.
Johansx where did you mount the board and the sensor?? I like that idea a lot, even more than the Alfa one. Would it be possible for this to just simply turn on the LED in the cluster that is not being used?? I dont need the 3 stage one just a simple system when there is no water the light must come on.
johansx
Post by johansx »
Gary57 wrote:The Madman thing does look good but I have most of those gauges in the car except oil pressure and temp.
Build this about 3 years ago.... :oops: still not mounted. Best place is probably to mount it at the highest point. Me thinks just where the top rubber pipe goes into the radiator. Yes, you can mount a simple LED only if there is no water at all. It comes with 3 LEDS, red, orange and green. Just extend the red 1 to anywhere on the dash. I want a red flashing strobe light and and a cow protter under my seat ... :lol:
Biggest problem is to build the level sensor fitting into the main radiator top hose. Spark plug electrodes with the ceramic insolator should work, just don't know if the steam will provide enough dampness to give a false reading.
Why cant you use the Golfs water sensor?? It work in exactly the same way. Where can I find that board thing in the electronics123 website?? I must look into the Golf thing a bit more.
johansx
Post by johansx »
Is the Golf sensor not some float with a switch?
Look for "Liquid Level Controller"
http://www.electronics123.co.za/Main.as ... goryID=923
http://www.electronics123.co.za/Main.as ... geNumber=1
The sensor board on the left needs replacing to fit into the water system.
The Golfs washer bottle use the electrode type.
johansx
Post by johansx »
Where is this electrode located, radiator or bottle? Picture anybody?
Bottle. It would be easy to mount that sensor in the upper radiator hose, make the hose out of stainless.
