8 port runner - JDM
That has been done before, cant recall how it turned out though.Gary57 wrote:PS: Why couldnt you use the 8 butterflies as ITB?? DO away with the main throttle body, move the accelerator cable to the low port 8 butterflies and there you have ITB??
ECCS is the Nissans fancy name for electronic fuel injection and timing...
If you have a hell of alot more vacuum pipes than you think you should have, then you have the 8 port.
Captain Slow to the rescue!
Emissions and MOT my dear Watson.... This is Europe we're talking about...Draco wrote:If the flow was improved why not the power....quite contradictory my dear Holmes
Now thats a contradiction!!!!Draco wrote:Ps. I am searching the net for some "facts"
Another tidbit for the imagination.
The CA is essentially a baby RB....
Nissan NEVER put the 2 port butterfly design on an RB (The do have ITB's though, but its a single ITB Per cylinder ) and there are no after market kits for it, why do you think that is?
Look, I'm not knocking the 8 port. I'm sure the power difference is minimal. If you have an 8 port, keep it, if you have a 4 port, congrats.
If you're at a point like VC where you can choose either for free, FFS take the 4 port!!! Less hassles, more flow...
PS, make sure your 8 ports are working correctly or you get the buildup in the photo's that VC posted....
Thats presicely why I say disconnect it, it does not work if the whole thing isn't done right eg vacumm tanks and all sorts, if it stays open I don't see why the flow will be worse...if you mathematically go and messure the 8 ports when butterflies is out and 4 ports....how much diffs will it make?make sure your 8 ports are working correctly or you get the buildup in the photo's that VC posted....
*sigh* OK here goes, it all boils down to fluid dynamics.Draco wrote:Thats presicely why I say disconnect it, it does not work if the whole thing isn't done right eg vacumm tanks and all sorts, if it stays open I don't see why the flow will be worse...if you mathematically go and messure the 8 ports when butterflies is out and 4 ports....how much diffs will it make?make sure your 8 ports are working correctly or you get the buildup in the photo's that VC posted....
Basically if you look at the air moving through the ports, the air "touching" the sides is "rubbing" and moving slower than the air in the middle of the port. Because the 2 port design has more "sides" it has more "rubbing" and less flow, while this isnt a problem at low RPM as the speed increases, the friction does aswell, also the air is under pressure so its getting forced against the sides aswell.
Also the single port is "bigger" in total, so there's alot more potential for flow. The 2 port has a chunk of metal in the middle.
I'd say stock for stock this wont be a big diff, but I think a 4 port gas flowed head vs an 8 port gas flowed head would make a huuuuuge difference.
As you say sokar, I am not dissing the 4 port either, to me it's the same thing if the buttelflies are disengadged, again, there are no scientific proof of the flow....no facts, I wouldn't base the link to a scientific fact.
At the end VC, as I said in the beginning, just because of the headgasget sets that come in 8 ports, I would rather buy a made up set rather than a cut myself job, it is up to you and the owner.
