Page 2 of 2
Posted: Wed Oct 03, 2007 10:00 am
Draco wrote:Nope...he cut it to match yours
interesting comeback!!!
i find the first hit is always better than the same (or is that lame) retaliation!!!
Posted: Wed Oct 03, 2007 10:04 am
True...something I don't understand....why would someone want their shaft as short as yours...it is very interesting...quite the oppisite of logic I suppose...but then again...the rules of logic don't apply when it comes to your short shaft
Posted: Wed Oct 03, 2007 10:09 am
veecee wrote:Draco wrote:Nope...he cut it to match yours
Funny you should mention lame....that fits nicely into the logic of your short shaft that might be lame but interesting.....ironic ain't it.
Posted: Wed Oct 03, 2007 10:11 am
by johansx
If you cut the cars std shifter shorter, the hand movement is shorter because of the shorter shifter. Since your hand still shifts at the same speed, the shorter distance necessary to cover the same distance, will result in a faster shift. If you move the pivot point higher, the shift will be even faster.
Personally, I would keep the longer stick, just move the pivot point higher.
Posted: Wed Oct 03, 2007 10:16 am
Draco wrote:veecee wrote:Draco wrote:Nope...he cut it to match yours
hmmm, thats worse than the first one.
Posted: Wed Oct 03, 2007 10:19 am
Ironic that you would think that hey....I expected more
Posted: Wed Oct 03, 2007 2:19 pm
by ChemCool
The only member who speaks sence here is johansx!!!! The rest speaks rubbish.
Posted: Wed Oct 03, 2007 2:25 pm
ChemCool wrote:The only member who speaks sence here is johansx!!!! The rest speaks rubbish.
i really resent that...
i've posted on this topic about the fact that cutting the shifter wont help to shorten the shift!
here's an excerpt:
this means that less throw will create the same movement below the pivot point. this does however call for the person doing the shifting to use more effort.
in short (scuse the pun) cutting the original shifters shaft will not give you a truely shorter shift. it will feel slightly different to stock but the amount of throw required to engage a particular gear will be the same as before!
i'm not so sure that angle has anything to do with it either. Wink
Posted: Wed Oct 03, 2007 2:31 pm
by ChemCool
Ja ok, just than crap in between you and Draco
Posted: Wed Oct 03, 2007 3:23 pm
What
If he did not get the answer in the first 5 posts he will never get it....so lets talk crap about vc's short shaft....with a kink higher up witch should not be cut....is that so difficult
Posted: Wed Oct 03, 2007 3:29 pm
by widowmaker
jikketies, whats on the smoking menu today?
Posted: Wed Oct 03, 2007 3:33 pm
widowmaker wrote:jikketies, whats on the smoking menu today?
did someone say smoking menu???
awesome, what you got???
Posted: Sat Dec 22, 2007 9:48 am
by GoldenEagle
Veecee....on the issue of effort when shifting....a weighted shift knob will lessen the effort needed to shift from one gear to another.
